2004 S430 ABS/ESP Please Help
Old Jul 23, 2020 | 07:11 PM
Steiny82's Avatar
s430
Cool 2004 S430 ABS/ESP Please Help
I have had this car since 2007 and have never had any issues with it. Recently the ABS and ESP indicators would come on and after resetting with the steering wheel they would go away. Now, they will not go away. I put a computer on it and it said front right speed sensor so I replaced it and nothing changed. Could it be the rotors? I have never changed them as I don't drive it too much, but love driving it when I do. Has anyone else had these issues? FYI, The computer is a snap-on and was able to clear the code out no problem but after driving for about 15 minutes the indicators came back on and here we are! Thanks in advance for any help!
Old Jul 23, 2020 | 09:33 PM
tusabes's Avatar
Mercedes
the key phrase in all that is you don’t drive it that much . By not driving it you are getting low voltage errors , and if you leave it parked outside you get corrosion problems on the brakes . Regular use will likely eliminate your problem
Old Aug 30, 2020 | 06:00 AM
turbonos7's Avatar
'05 S430, '05 S600
Your speed signal is not taken off the rotors themselves but from the inside part of the wheel bearing. It has a bunch of small teeth which is what the sensor picks up to detect speed. Also find someone with DAS and they might be able to read more into the problem.
