2001 S430 does not stay running for long, strange electrical issues
My imported S430 had been an enjoyable every day driver until recently. It made a cross country drive almost without issue, but when we were almost home strange electrical things began going awry. The power windows would not always be operable, sometimes you couldn't get them to open, sometimes they worked just fine. The instrument panel fades in and out. The sunroof will not open unless you repeatedly bump the open switch, and same for closing. Sometimes the car will die right out if the windshield wipers are in use. The alternator and battery have been replaced, and the alarm module has been removed as it had an internal short that would trigger the lock lights and tone intermittently, draining the battery. I would like to address these things soon so I can sell the car, if anyone has had experience with these issues please lend me your wisdom.
. Usually a problem affecting the windows and cluster is the door control module (the power seat switch panel In the door ) they are tied into everything and when they fail all kinds of weird electrical errors occur , and they fail often
other electrical issues can be with the SAM front or rear
for me the best bet is to get a door control module On eBay and swap it out and see if it fixes your problem . It takes 10 minutes to change
