Coil Pack Options?
Old Aug 20, 2020 | 08:43 AM
Fried Chicken's Avatar
2005 S500 Designo
Coil Pack Options?
Mercedes OEM: 000-158-78-03-80; Cost: $74
https://www.mboemparts.com/oem-parts...UtMGwtdjgtZ2Fz
Bosch 0001587803; Cost: $56
https://www.fcpeuro.com/products/mer...il-bosch-00107
There are numerous chinesium options out there. Are they any good at all or is it not even worth a sideways glance?
More basically, what are the symptoms of a coil pack going bad? I’m chasing down a vibration, and I’ve tried pretty much everything else I can think of to fight it.
Old Aug 20, 2020 | 07:48 PM
tusabes's Avatar
Mercedes
Bad coil pack usually throws a misfire code
the Chineseum can work at least for testing . Try them out and see if it helps
Old Aug 30, 2020 | 04:14 AM
turbonos7's Avatar
'05 S430, '05 S600
Are you getting any P300 codes on your OBD-II scanner? If so, swap the coil pack around to another cylinder and see if the misfire follows.
