S600 W220 Broken Cylinder Headbolt?
Champouelle1
Champouelle1
Does your engine have 'internal socket head bolts' requiring a TORX 'allen key' inserted into the bolt head or the newer style that require only a standard metric socket.. Those that require use of a 'Torx allen key' that INSERTs INTO the bolt head MUST BE REPLACED.Those bolts are prone to breaking off where the head and shaft join AND are much too prone to corrosion--leading to bolt failure and head gasket leaks.
Your Dealer might free-replace all your head bolts if they are the 'socket head' ones. There were both Technical Service Bulletins and MB programs to replace all the socket heads , including removing cylinder heads etc.
Man, don't mess with this. The broken bolt will on the V12 hit the cam shaft, and then things get totally messy.
Did you measure the the head bolts for stretch before re installation as per WIS?????
Deadly if you didn't.......change them all!!
Champouelle1@yahoo.com
champouelle1
Champouelle1
If you didn't, you have to replace them all, as one broke during torquing.
No wishful thinking here.
The aluminum alloy cylinder block is ALSO flexible and a broken head bolt will allow the cylinders next to the missing bolt to flex to out-of-round and cause piston scuffing and cylinder wall. damage. The cylinder bores are finished with a 'torque plate' bolted onto the block to simulate the clamping pressures and distortion resulting from head bolt tension. This ensures the cylinders are perfectly round during operation
Will the head gasket fail and leak if the engine is operated with the broken head bolt? Probably. Will it run for a while if driven easy? Maybe These head bolts are tightened to the 'stretching point' and are permanently stretched by the proper tightening. These bolts ARE NOT REUSABLE. IF your engine has the old style Internal-TORX socket head, they must be replaced in any case because they will fail in service right where the stem flares out to make the socket head.
Everyone of my bolts was in the "like new" values, so I followed the "reuse" instruction.
I believe the headbolt problem started on the M275 engine, when higher power and boost was implemented.
Anyways, I did my engine in 2014, and it has run just fine since then (must have done something right).
BTW: These bolts are torqued to stretch, NOT to yield! (on the M137).
But yes he is in trouble, and has to re-do it!
Champouelle1
Did you use WIS?
If you are really lucky, the drill bit will enter the bolt and then stick, and slow, careful turning will back it out of the hole. I think that the fact that you simply pulled the bolt in two with excessive torque is better than the bolt seizing in the threads would have been.
All this being said, you may still be screwed. You over-torqued every bolt. If one or more of the bolts fail when the block and heads expand from the heat of normal operation, you may get significant engine damage. You might be driving a grenade with a loose pin...
Consult with a Drill Manufacture about the best bit point and sharpening angles. A high tech specialty machine shop will not be cheap, likely a couple of hundred dollars, but this is not the place to dicker on price. You MUST get absolutely straight, centered, 'running fit' in the hole in the head. Be sure and leave enough good metal in the drilled hole walls so the 'easy-out' will not bulge the bolt shank
I think the easiest way is to just pull that head off and start again.
And, where did you get instructions with the head gaskets?
Not MB.
Good luck!
May you have good success in this unfortunate task that resulted from bad information -- MBZ does not issue new WIS versions for every Service Bulletin or Special Instructions, or Special Warranty Campaigns. They presume 'Authorized Service Personnel' remain current on ALL INFORMATION they publish.
