Jamed seats after reinstall
Old Sep 17, 2020 | 05:22 PM
alex sabin's Avatar
w220 s500 4matic L
hello,
because my car was not used for more than a year, and the last owner didn't care about the interior, i decided to take out the seats for some lube time, and contact spray on all that is there.
i placed them inside, and all the control work beside the back rest that is in full vertical position. both the driver and the passenger seat are the same.
when i touch the control you can hear under the seat as the relay works but the chair isn't...
is there a way to fix it ? do they need to be relearned ?
my car is a w220 2003 S500 4matic L
Old Sep 21, 2020 | 12:46 PM
alex sabin's Avatar
w220 s500 4matic L
problem solved.
took everything out again, contact spray...took the fuse out - contact spray - mount everything back - works fine.
case closed.
Old Sep 21, 2020 | 02:56 PM
wallyp's Avatar
2003 S500 2007 GL450
Thank you for the follow-up - not enough folks do that.
