P0410
Old Sep 27, 2020 | 01:04 PM
Urquizo's Avatar
2004 s430
P0410
. I have a 2004 S430 with a P0410 code which is the Secondary Air Pump emissions error code. I've replaced the SECONDARY PUMP with the relay and have cleaned and replaced all hoses that pertain to the secondary air pump. After replacement and cleaning, the code came back after 100 miles of driving it. I do not see a main fuse for the secondary air pump, is there a fuse that I don't see on the fuse diagram? But here is my main question before I order a second secondary air pump. I disconnected the pump and checked for output voltage from the two PIN connector that connects directly to the pump. I get 0V output. No power, I am starting to suspect the problem is the pump is not getting any power. Or does the pump start immediately when I turn on the ignition switch? What sends the power signal to provide voltage power to the pump?
Old Sep 27, 2020 | 11:38 PM
wallyp's Avatar
2003 S500 2007 GL450
The pump runs only for brief intervals to lower exhaust emissions during warm-up, at idle, etc.
Go here https://www.benzworld.org/forums/w220-s-class.25/ register and fill out your info, then search that Forum for info on "P0410". There are several possible causes for your code.
