MY KEYS WILL NOT TURN IN IGNITION!?
Old Sep 30, 2020 | 02:29 AM
W220BossDon's Avatar
W220
I drive a 2001 S430. When I put my keys in the ignition, it will not turn. The steering wheel will come down, the dash is lit up with all lights, but refuses to move from the “1” position in the ignition. Furthermore, when I remove the keys, the gauges do not turn off, and I can hear the blower motor running(I think it’s the blower motor). I’ve been disconnecting my battery in between times I’m not messing with the car due to this issue. Also the steering wheel is not locked in place, even though the car is in park and battery disconnected. HELP ME PLEASE!!??
Old Sep 30, 2020 | 03:25 AM
tusabes's Avatar
Mercedes
Did it work before fine and is this a new problem or did you get the car with the problem ?
most often it’s a weak battery . Or else it’s the ignition switch which you can’t swap unless you change 4 parts - key shifter ignition switch and ecu from a donor car
Old Sep 30, 2020 | 03:29 AM
W220
it did work before fine. I had this issue one time before because my battery was dead. I got a jump and subsequently a new battery and was fine. Then the problem came back a few weeks later after driving the car regularly.
Old Sep 30, 2020 | 09:45 AM
wallyp's Avatar
2003 S500 2007 GL450
Some possibilities:
Loose or faulty battery connection. Check the positive connection and both ends of the ground/earth cable for cleanliness and tightness.
Corroded or loose connection on one of the major primary fuses. One is behind the trunk lining just forward of the battery - it usually doesn't cause a problem, but you need to be aware that it exists. The main possible problem area is under an aluminum cover under the front passenger carpet. If the reed valve at the bottom of the HVAC inlet plenum under the hood gets plugged from debris, water can overflow into the car under the carpet. There will be no visible sign of water! You need to pull the carpet and all padding up and check for any signs of water or corrosion. If you have traces of water or corrosion, you must take care of it, or you will have major problems.
As tubsades says, there are other possibilities - the only way to really see what is going on is to get the car connected to one of the Mercedes diagnostic systems, either at a dealership or at a good independent shop whaic has the system and knows how to use it.
Old Sep 30, 2020 | 09:47 AM
W220
Originally Posted by wallyp
Some possibilities:
thanks, I’m going outside to mess with the car now
Old Sep 30, 2020 | 02:26 PM
tusabes's Avatar
Mercedes
maybe your car is not charging your battery and it’s weak again
Old Oct 4, 2020 | 10:50 AM
W220
Some possibilities:
I think it may be the ground wire. I got it to start and drive perfectly by messing with the wires, but I can’t replicate what I did.
Old Oct 5, 2020 | 01:16 PM
Kebowers47's Avatar
001 s600, 94 sl600
I strongly suggest you remove, clean and treat ALL the ground wire connections to everything. Use Stabilant-22 to treat the connections--it is by far the best treatment to use.Good parts stores can order it or you can order it online (Stabilant -22)
I once drove a 1964 VW-Bug back and forth to college (72 mile RT)-4 years, and in the third year at the beginning of fall semester--it acted like a dead battery, but battery tested full, but nothing anywhere in the car. I kicked the bumper--and it would then start and was fine for a few days--then again, and repeating at more frequent intervals,
I began checking all the connections---and found the flat stranded wire battery ground cable, which look pristine and as-new, was 'attached ON_TOP' of the good black anti-corrosion paint and the attaching bolt had been the ground path until it got corroded. I cleaned the paint off and never had that problem again. BTW, the oh-so-weak 6- 'volt headlights and 'high power 'Driving Lights' were significantly brighter then. The lights were finally bright enough to see safely at highway speeds!
Old Oct 9, 2020 | 01:06 AM
W220
GOT IT!!
After checking all SAM units to no avail, I looked at the footwell on the passenger side. Upon inspection, the plug to the upper most right was loose. When I disconnect it, the volts drop from 14.6 to 13.6 but it starts up and drives perfectly. If I connect it, it goes back to the ignition not working and dash staying on. What is this wire and how do fix this issue??
Old Oct 9, 2020 | 02:07 AM
tusabes's Avatar
Mercedes
These wires go to your pre fuses , your fuse block under the wires probably got water damaged
Old Oct 9, 2020 | 02:10 AM
W220
The red wire there to the top right is exactly what I’m talking about. There doesn’t seem to be any water damage to the car anywhere. When I plug it in, it sparks a little, but idk if that’s normal.
