S600 Distronic randomly disengages
Old Nov 2, 2020 | 02:09 AM
WTFauto's Avatar
S600
Well, when I use distronic, it has a habit of simply disengaging when following a car and beginning to brake. As you can imagine, this is the scariest time for the car to suddenly stop braking, I have to react fast every time to avoid a crash!
I tested it for about 30 minutes when driving behind my Lexus GS which is a large car, and it had no problem. But it seems to have trouble with other cars? One time, it lost sight of the car in front of me when going around a slight bend when doing ~45mph on a 60mph freeway and just started accelerating toward the car in front of me!
Driving this car with distronic is like being in 'Final destination'
Any clues? I noticed the sensor has directional adjustment via the 3 screws, is it particularly sensitive to being perfectly calibrated? If so, how is it done??
Though I suspect my fault must be far more serious than this.
The vehicle does not throw any fault codes at all. Distronic can be re-engaged immediately after it self-disengages. In fact the disengagement seems quite a lot like what you get when you tap the brake pedal. Makes me wonder if the brake pedal switch is dicky.... But I see no evidence of it (flickering brake lights)... unless it is one of those two circuit switches and just the cruise circuit is faulty, but the light one is ok?
Old Nov 2, 2020 | 07:46 AM
wallyp's Avatar
2003 S500 2007 GL450
That seems dangerous enough to absolutely require an accurate diagnosis on SDS.
Old Nov 2, 2020 | 08:49 AM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
What year car? If you search my nick (here and there) I have reported on this problem most likely the new surround surveillance systems of recent car models causing interference.
Old Nov 3, 2020 | 12:28 AM
WTFauto's Avatar
S600
2003, early biturbo. It happened to me today in the middle of nowhere, no buildings, cars or tech near me, just trees. Interestingly I've been watching the display and I think its detecting phantom cars very closely and thats whats causing it. I saw a car pop up on the display for 1 second then disappear when nothing was actually there.
What can cause the radar thingo to detect false positives?
Old Nov 4, 2020 | 12:14 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Q: What can cause the radar thingo to detect false positives?
A:
Radar jamming from other radar transmitters, which have proliferated with blind spot monitors and other autonomous braking systems.
Is this true on your car? Time to hook it up to SDS and see if you've got an intermittent radar "thingo" or, if it's good, you're getting jammed.
Old Nov 5, 2020 | 01:57 AM
WTFauto's Avatar
S600
A:
I'm confident its not A, given the frequency it happens including with no one else around. Does the SDS give a lot more information? I've been pondering getting one but so far every problem has been an easy fix so it was not needed.
Got a buddy looking out for a panasonic toughbook.
Old Nov 5, 2020 | 08:33 AM
kraut56's Avatar
On my car most of the times it is displayed as "DISTRONIC EXTERNAL FAILURE" (or something similar), i.e. not a system failure.
Of course only on the highway. Distronic in city driving seems ok, as speed control is normally not active.
