Alarm goes off in garage without reasons
Old Jan 16, 2021 | 01:46 PM
Koelwx's Avatar
Mercedes GL320
Any suggestion what to do ? Change the siren ? How to take siren out ? Cost for repair in workshop?
Old Jan 16, 2021 | 01:51 PM
tusabes's Avatar
Mercedes
the alarm siren box has an internal lithium battery that has failed
get w new alarm siren box from the dealer
used ones have old batteries
the front fender liner must be removed
here are some pictures to disconnect the siren
https://www.benzworld.org/threads/al...#post-18129337
Old Feb 1, 2021 | 08:10 PM
Hubbard 0's Avatar
S55 AMG
Super easy fix, you just need a new siren unit. I found mine on Amazon for $140.
Remove front right wheel, remove fender liner.
The alarm will be tucked in back there, undo bracket that holds it in and replace.
I did find that my replacement alarm didn't have a mounting stud on the back like factory unit did. So I had to scrounge up a small bolt to attach the new alarm to the bracket. Keep this in mind when you start in case you have to run to a hardware store.
