Front end Questions, Trans mount
I installed new front lower control arms. car rides better, but i do hear a "snap/pop" when turning, or when load changes (going back, or forward, or stopping or taking off) and its not totally consistent but it is more consistent than not. OEM units were installed, and included new ball joints on the knuckle side.
what exactly would be causing this?
Also, what specifics would i be looking for if the upper control arms are bad?
Also, as for transmission mount...what are the typical signs on these cars. I havent gotten it on a lift to check it, but planning ahead. i suspect it is bad anyways but wanted to hear some confirmations of signs of a bad one.
03 S500 4matic.
03 S500 4matic.
Sorry you won’t be getting help in this forum due to the way you interacted with others here
https://mbworld.org/forums/s-class-w...s-airflow.html
