Air vents/Airflow
Old Jul 24, 2021 | 12:25 AM
tackleberry23's Avatar
S420
Air vents/Airflow
03 S500. Wondering where to look to get full airflow from all vents....
Center vents, full speed and work fine
the outer vents (by the doors) very weak air flow.
Old Jul 24, 2021 | 09:34 AM
wallyp's Avatar
2003 S500 2007 GL450
The airflow is adjustable. The small handwheel at each vent can adjust flow from none to full, with the bar in the center of the adjustment level setting "auto", or computer control. If that doesn't work, you will need to get the car on SDS, where you can test each of the airflow actuators.
The "Owners Handbook" is actually a good 6" of reading material. There will be quite a few surprises in there...
If you don't have the books, free downloads are available on-line.
Old Jul 24, 2021 | 09:42 AM
S420
thank you captain obvious. they are all set to fully open this isnt my first car.
your unhelpful sarcasm is noted.
sheesh, i miss the helpfulness of bmw community. its def not the same in the benz world
Old Jul 24, 2021 | 01:36 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
A$$hole newbie!! (joined 2011???)
Go away!
Old Jul 24, 2021 | 01:56 PM
tusabes's Avatar
Mercedes
Wally gave you a detailed helpful answer
you won’t be getting any other help here better find your own solutions
Old Jul 24, 2021 | 02:30 PM
wallyp's Avatar
My apologies for not recognizing your outstanding level of knowledge and experience from your simple question. I'm not really certain what part of a serious answer struck you as sarcasm - but I can assure you that it won't happen again.
Captain Obvious, AKA
Old Jul 24, 2021 | 04:53 PM
S420
Go away!
thanks for proving my statement as fact
Old Jul 24, 2021 | 04:55 PM
S420
wasnt getting any to begin with, so obviously no different. funny how theres more responses on this than there are actual discussions. i stand by my statement as "RTFM" mentality isnt useful.
Old Jul 24, 2021 | 04:58 PM
S420
your answer consisted of reading the manual and opening the vents, as if those extremely obvious things to check wouldnt be done already.
Old Aug 8, 2021 | 07:15 PM
paste's Avatar
I have the same problem.
Old Aug 8, 2021 | 07:19 PM
paste's Avatar
It's something to do with the flaps; they will blow full power in diagnostic mode when the center vents are off. It's just the center vents are off entirely when that happens. I'd settle for equal airflow blowing from all vents but I don't know how to manually adjust these flaps, it's either open or closed.
