Transmission electrical connector or socket
Ok, so this info is regarding the electrical connector/plug on the mercedes nag-1, 722.6, 5-speed transmission. More specifically regarding the w220 2003 s55. This info should be the exact same for all nag-1 transmissions no matter what vehicle it is in. Will most likely carry over to nag-2 and possibly further iterations as well. But someone far more knowledgeable than i would have to speak to that.
If one does any searching for transmission service on the nag-1 or 722.6 you will likely come across the notion that it would be prudent to replace the connector/plug when doing said service due to possible wicking issues if seal(s) break down. What i found out was that the supposed oe replacement part was not really up to the task of the original oem part. It is a little more fragile with seemingly less tolerance adherence. Almost a bit janky. Maybe that is all in my head but was not able to get the replacement part to work for me. Anyway, the reason i bring this up is that should someone ever wish to make sure the wicking issue doesn't happen to them, and are worried about a part that is perhaps not as well made as the original back in the day, then maybe the following measurements will help to save time and headache and a little money.
I took measurements of the plug and this should allow someone to source the replacement seals for less than a dollar. Yes, the plug isn't really that expensive to begin with. However, if you just want to source the 2 o-rings that should not be an issue with as long as your plug/connector is not broken or cracked. If you don't force anything is should come out fairly easily. There is even a built in pry point along the tranny and plastic collar to allow one to gently pry/slide the connector out of the socket. Well, at least to get it started. With a light on the part, and the lever in the down position you should be able to realize what i am describing just under/below the white level/tab on the rotating slide lock.....rotate up to lock down to unlock. There is a small lip on the black part of the plastic to pry against, and a tab on/near the tranny electrical port to work as a fulcrum for a flat head screwdriver.
Keep in mind these measurements where taken with my micrometer. I do not have schematics or proper manufacturer measurements/diagrams of the seals/o-rings. If the seal(s) you find are off by less than .2 or .3 i "think" you should still be ok with proper sealing of the unit.
Be sure to use viton o-rings. And don't forget to wet the o-rings with new atf fluid so help the new/renewed part slide back into tanny.
Smaller o-ring.....
35mm......this is the measurement on the connector where the smaller o-ring will seat/sit once on the connector/plug itself. So considered the OD(outer diameter) of the plug.
32mm(ID).....this is the INNER diameter of the smaller o-ring/seal before mounting on plug/connector
37mm(OD)....this is the OUTER diameter of the smaller o-ring/seals before mounting on the plug/connector
2.6mm(dia)....this is what is considered the 'thickness' of the o-ring before it is mounted on plug/connector(caveat: measured with micrometer so ranged from 2.5-2.7 depending on area measured and how lightly i touched the o-ring)
Larger o-ring.....
40mm.....this is the measurement on the connector where the LARGER o-ring will seat/sit once on the connector/plug itself. So considered the OD(outer diameter) of the plug.
38mm(ID).....this is the INNER diameter of the larger o-ring/seal before mounting on plug/connector
43mm(OD)....this is the OUTER diameter of the larger o-ring/seals before mounting on the plug/connector
3mm(dia).....this is what is considered the 'thickness' of the o-ring before it is mounted on plug/connector
Hopefully someone can find this info useful. Keep in mind the replacement part is only 15-20 bucks(did not look up what the dealer 'real' oem part costs) so you decide which way you wish to go. Seals can be had for under 1 dollar.
Edit: so to be clear it is my understanding the break down, or hardening, of a/the seal(s) is where the trouble can be found.
