How to Remove TELE-AID Module completely from W220 D2B optic-ring.
These instructions are likely pretty close for MOST optic system that replaced D2B optics in 2004. The following was performed on a W220 S55 AMG 2003 model with chassis 174 that has a D2B optical ring.
I did this from memory and a few notes along the way so I hope I got this right and will edit this later if required.
Use the Mercedes Benz Fiber-Optic Bypass Coupler to by-pass the TELE-AID module that is located under the rear seat on the passenger side. This coupler is available from your dealer for a few bucks. Disconnect the electrical connector to the TELE-AID and remove the module from the car. To identify it, it is the only module beneath the back seat that has the orange fiber-optic cable.
Several modules are affected that need to be coded differently in SDS as follows:
Cluster->Control Unit Adaptations->Variant Coding->special equipment. Set "TELE-AID or E-CALL” = NOT PRESENT.
Cluster->Trouble Shooting by means of complaint or symptoms->Following Engine Start the Message “TELE-AID Defective visit workshop” appears in the display->set “Instrument and communication system” = NOT PRESENT.
Airbag->control unit adaptations-> Read codes and change if necessary->vehicle equipment->Set Emergency Call or E-CALL = NOT PRESENT.
CGW-> control unit adaptations-> Read codes and change if necessary->COMAND or AUDIO-> Set Cellular Telephone = NOT PRESENT, (not sure if this was required, but it did not affect by Bluetooth puck into the COMAND.
Go to the sub group of Modules listed: “Audio, Video, Navigation and Telematics”->D2B – COMAND or AUDIO->Actual Values of D2B Components->Actual Configuration of D2B components. Note down the current order of D2B components in the ring. This list should be something like this:
Radio(COMAND, Master), Sound System(AMP), CD Changer (if fitted), Cellular Telephone (used by your Bluetooth Puck if installed), Voice Command(If installed), TELE-AID.
Go Back one step to Control Unit Adaptations->Read codes and change if necessary->Specified Configuration of D2B components->Change the TELE-AID = VACANT. Restart the optical ring.
Clear all Error codes on each module.
Do a Quick-Test and Confirm all is good.
Check on COMAND that your Bluetooth phone still works, the CD player, the radio, Language Module, and the Navigation works.
Check your cluster that no errors are reported. I would be interested to get feedback when someone tries this so we can confirm this process, or edit for accuracy.
Although everytime I switched the option to send a call in case of a wreck, (the option under airbag). My airbag warning light comes on instantly and I can't get it to turn off unless I go back and switch that option back on
that
is the only thing under rear passenger seat
I just got my star c4 kit. I am going to attempt your procedure to a 2005 CL 65 AMG.
First question: I have a lot of software on my machine. What software did you use to code the controllers with (sorry I am new to this)
Second question: Did anyone (by your knowledge) try this procedure on a CL?
Thank you very much
