Brake pedal excessive travel
Old Jan 15, 2022 | 02:19 PM
Dutch D. Clutch's Avatar
S430, W113 280SL, 220d, W114 250, 300E
My 2000 S430 started having excessive brake pedal travel and in conjunction, the anti-lock 'thinks' the wheels are locking when they are not, anytime I push the pedal about halfway in this long travel. Normally with this much brake pedal travel, I would expect the master cylinder. But the ABS malfunction adds another element. This makes the car impossible to stop quickly as the ant-lock kills the foot pressure on the pedal. Any suggestions on what component to investigate initially?
Old Jan 16, 2022 | 11:51 AM
Kebowers47's Avatar
001 s600, 94 sl600
A good diagnosis with SDS is essential to finding the failed component in this case. You should not just throw new parts at it. There are several systems that interact in the brake system and cause such failures.
Old Jan 23, 2022 | 11:22 AM
Thanks. A code reader did not reveal anything relevant. A Mercedes master-tech suggested the symptoms could be that of an internally by-passing master.
Which brings up a bleeding question ... See next
Old Jan 23, 2022 | 11:24 AM
Continuing exploration:
We just installed a new master, as a Mercedes master-tech suggested the symptoms could be that of an internally by-passing master. When we bled the right front caliper, we got a constant stream of fine air bubbles which do not stop. Yet when we close the bleeder and step on the brake pedal there is no brake fluid leak, and we are not losing fluid. Yet we continue to have a soft brake pedal. Any ideas on this? Someone said rather than old-school bleeding, we need to power bleed.
Which brings up another question, in power bleeding, should one push the fluid down from the reservoir to the calipers or up from the calipers to the master?
