Soft Close and Door Lock Not Working
There are dozens of threads on the Forum on this subject. Start by going to the thread whose title includes "...START HERE..." in the stickies (the blue area) at the top of the first page.
Basically, there are two pneumatic actuators built into each door look assembly (and the trunk latch assembly). These are plastic housings containing a rubber diaphragm, and failure of the plastic housing is the most common problem.
On the door lock assemblies on my 2003 W220s, the soft-close actuator hangs down below the assembly, and can be repaired. Unfortunately, the door lock/unlock actuator is buried deep inside the assembly, and I could find no practical way to disassemble the lock assembly. Each of the four lock assemblies are unique, so you will need a lock assembly for the 2000 W220 left front door. Factory part only - the installation is expensive enough that you do not want to cheap out on an unknown assembly.
Research on-line will give you the part number, and will give you numerous vendors (many of them individual Mercedes Benz dealers, some cooperative dealer groups, some independent parts vendors). Research here can save some money. The lock assembly will not be cheap.
Installing it will also not be cheap. I hope that the mechanic is either very experienced, or is willing to do some serious research on how to do the job. It isn't simple.
Good luck!
