Scanner recommendations ?
Old Nov 17, 2022 | 12:03 AM
Benznew2005's Avatar
2005 s430 matic
05 S430 4 matric.
Looking for a decent scanner on Amazon for the above ,New to me , ride .
They say they are StaR compatible for about $135 and up .
Thanks!
Old Nov 17, 2022 | 02:57 AM
tim687's Avatar
CL 600 '00 5.8L V12
Get yourself a DAS/Xentry setup. It's well worth the investment, actually you can't really perform any diagnosis if you don't have one.
Old Nov 17, 2022 | 03:52 PM
2005 s430 matic
Will do
Thanks ! Yea I have a couple for my BMW but wanted to something Star compatible.
Old Nov 18, 2022 | 09:57 AM
wallyp's Avatar
2003 S500 2007 GL450
"STAR Compatible" sounds like sales weasel scam-talk to me...
Old Nov 18, 2022 | 11:09 PM
brooktre's Avatar
W220, R170, XU70
From what I’ve read there are some readers that will get most of the MB codes in that price range. If you search the forum you’ll find some options. I can’t recommend any because I’m not familiar with them.
However, none will give you everything that Star gives you. If you DIY and plan to own the car (or any used MB) for any length of time then Star is well worth it.
Old Nov 19, 2022 | 01:57 PM
CooperK's Avatar
S500 2005
Originally Posted by Benznew2005
05 S430 4 matric.
Thanks!
I just bought an Inova 3100rs at AutoZone for $120, same price as Amazon.. It gives me all the info I need for my 05 S500 and 04 BMW 330ci. It has a 'library' function where I guess you can go for more info. They give you app info to link it to a professional service that will read the info and diagnose. Of course they will advise you to go to a shop that is somehow linked up w them. I downloaded, looked around and deleted. I'm 50% diy and 50% to my indy guy.
Old Dec 16, 2022 | 08:58 PM
Hank Houston's Avatar
S-600 w220, Nissan s13 coupe, and Nissan s13 convertible
iCarsoft Mb scanners are pretty good for the price. It reads codes and if I remember correctly it can also do some variant coding. It's a little tiresome to use since it's not touchscreen but it does the job. My autel scanner does a lot more variant coding. I wish I had gotten the more expensive unit after finding out it can do more coding and even change the Vin. That unit is $3000 though. The one I got can program tpms and stuff. I use it to clear engine codes.i use it most toreset my hydraulic truck whenever its acting up. When i first got my s600 my trunk wouldnt open or close. I thought the pump was broken but turns out the computer that controls it was shut down and had to be reset. If you do get one that does coding I recommend taking pictures of all the settings before you mess with it. I accidentally deleted my vin from my eis unit. It doesn't affect operating the car but it does throw a code when I scan it
Old Dec 20, 2022 | 02:02 PM
e350forme's Avatar
fleet
foxwell nt530 for Mb will help you clear or check any module. (enough for home mechanic if we can call ourselves that)
its like 125 bucks only
