COMAND upgrade for 2000Model S-Class
Old Oct 20, 2004 | 06:04 PM
shaunconn's Avatar
Question COMAND upgrade for 2000Model S-Class
I have a UK 1999 W220 (Yes, it was out 6 months earlier in Europe than the US!0, and wondered if there was an upgrade for COMAND? I have downloaded the ISO for MY01 off geocities, but unsure whether my version is upgradable, and want to be *really* sure before I possibly wipe my COMAND system.
The Mute+1+3 shows me for FIS H/W 22.98, S/W 40.99, Production Date 08-02-99. And if it helps, SH decoder V5.17 OMS_EU, Navi BIOS 861.22...
On another point - the Navi seems to be CD not DVD (so I assume I can't get TMC)?
Any help appreciated!
Regards
Shaun
Old Oct 20, 2004 | 06:26 PM
awiner's Avatar
2003 CL55 AMG
The MY01 update CD should work and provide you with the latest Navi 2.5 firmware.
Old Oct 21, 2004 | 03:12 PM
tmushy's Avatar
2012 CLS 550
honestly i recommend just buying the latest cd from the dealership or iv seen it online for 50 bucks. thers alot more features that is added to the navi firmware that the 01 software.
once u stick the cd in it shows a screen that upgrades the firmware.
Old Oct 21, 2004 | 03:33 PM
stenen's Avatar
Regards
Shaun
Sorry Shaun, in Europe it is not possible to upgrade the Comand from 08-02-99. You have the Software Standard. From 01-09-99 has the Comand Software DX. Learn more about it here.
http://www.blaupunkt.co.uk/nav_cds.asp
Old Oct 21, 2004 | 03:52 PM
shaunconn's Avatar
Hi
OK - I'm confused now. One says the MY01 download will do, another says I should buy a CD from MB, and a third says it can't be done.
The site link to blaupunkt is surely just for the navigation software though - its nothing to do with a COMAND upgrade is it?
Is there anybody specifically with the same release as me who has upgraded (anything!) successfully?
Shaun
Old Oct 21, 2004 | 04:00 PM
tmushy's Avatar
2012 CLS 550
well let me explain
when u buy the new cd it adds features to your command system that wernt available before.. for example when your typing in the street names it automatically removes the letters that arnt available. I know on older model it doesnt do this.
also with the new cd you get the latest streets and updated locations.
Old Oct 22, 2004 | 04:44 PM
shaunconn's Avatar
Hi
You misunderstand - I know what the upgrade might provide, but I'm confused by whether the download will work or I have to actually buy a CD - which is a challenge as my local MB dealer have never heard of such a CD.
Shaun
Old Oct 22, 2004 | 07:12 PM
awiner's Avatar
2003 CL55 AMG
You guys aren't undestading the origianl question. shaunconn is refeering to the COMAND FIRMWARE update, NOT the Navigation Update/Yearly release CD.
The COMAND FIRWARE update is something that ONLY MB serve centers can get, unless you find it on the net like shaunconn has.
MY01 is the latest update for COMAND 2.5 (As used in the 2000+ CL/S Class 1999 in Europe as per shaunconn)
Now, as to what stenen knows, I am unfamiliar with. However, it is worth looking into.
I also suppose you have the instructions on how to enter the update menu for the CD Firmaware flash shaunconn ?
Old Oct 23, 2004 | 02:44 AM
stenen's Avatar
Hi
Shaun
Sorry again, The MY01 is for the Comand with DX. You need the CD 220 589 00 22 00. I had it when I installed the TV-Tuner in my early W220 S-klass.
PS.
I still have the CD, if you need a copy give me a message.
Old Aug 30, 2007 | 02:07 PM
Korso's Avatar
S500 - 2002
Upgrading firmware on Comand 2.5
Hello, I have same problem just like shaunconn has ! I would like to upgrade my comand but the MAY01 that I have downloaded it doesn't working,just like shaunconn ! However I appreciated if you help me out.Best Regards, Khorso
Old Sep 1, 2007 | 11:29 AM
lloyds's Avatar
2004 CL500
Hi shaunconn,
I have already tried updating my comand using the my01 update cd for none DX comand. my 1999 system says that the firmware already installed is the same as on the cd.So I updated anyway and after 40+ minutes the system was still the same. If you wish to try it your self here are the installation instructions :-
COMAND MY01 UPDATE INSTRUCTIONS
Applies to COMAND 2.5 (maybe 2.0)
This update includes how to:
- update with CD
- apply same update TWICE or more (running MY01 twice removes any custom logo).
- recover from crash or fail
- prevent ICAN loops
__________________________________________________ _______________
1 Switch off ignition and withdraw ignition key.
2 Switch on operating unit with ON touch switch and wait about 10 s until operating unit is correctly switched off.
3 Press keys * and # at the same time and hold and switch on unit with ON switch. Wait until download screen is displayed, then release keys.
4 Insert download CD. (In the case of CD version with automatic CD eject, CD is ejected and must be inserted once again).
5 Press the following keys to override an older or same version: First of all RET alone, then 23 and 9 at the same time.
6 For download with ICAN activity (if ICAN active, download stops endlessly in the case of checking CD) press keys 1 and 3 at the same time (before start of download!)
7 Start download by selecting with start operating unit rotary knob and press on rotary knob.
8 The download now runs automatically in two stages and takes about 45 minutes in total.
9 Confirm final message with OK, remove download CD and insert NAVI map CD, switch unit off and on with ON switch.
Procedure in the case of download problems
If the download does not continue running or takes significantly more
than 45 minutes:
Remove fuse F61 (for radio/sound/COMAND operating unit and navigation) and insert again. This fuse is located in the right below the rear seat bench in the footwell (fuse and relay box below right rear seat). The fuse box is enclosed with a black rectangular plastic cover and can easily be opened without a tool. A drawing of the fuse assignment is provided at the vehicle tool kit in the trunk above the spare wheel. F61 is the 5th, counting from the middle of the vehicle, and the 14th, counting from the door (long row of fuses with a total of 18 fuse positions, not all of which are fitted). The fuse may be located in a different place on your vehicle. If in doubt, consult your handbook.
After this, once again start the download process.
Old Sep 27, 2007 | 04:47 AM
stevemok's Avatar
sl500
PS.
any chance to have a copy of the cd
Old Aug 7, 2008 | 10:46 PM
orp967's Avatar
2007 S550
Anyone still have a copy of the update?
I just purchased a used 2000 W220 that was manufactured in 08/1999 so it uses the type C discs and I was wondering if anyone still has the update disc to convert it to the DX discs. Any help would be awesome thanks.
