My defroster and center vent doesn’t blow heat 🤬
Old Mar 30, 2023 | 07:52 AM
Mookie1987's Avatar
2015 Mercedes-Benz S550 4MATIC, 2021 GLC300 4MATIC Coupe and 2006 S500 RWD
Hey I recently had redone my whole cooling system after having a bad radiator and water pump it was leaking coolant. I used a quick fix to stop the leak while they were bad ( Don’t kill me y’all lol I was kinda broke then). I change the coolant, thermostat, auxiliary water pump (duo valve), water pump, radiator and upper radiator hose . My heat worked fine before but now all the front heat works expect the defroster for the windshield and the center vent. I’m bamboozled 😂
