Only Truck lock working remaining stopped
i have a problems in my Mercedes w220 s320 2000 model
The first problem is i can open and lock trunk using key and driver door switch i mean only trunk working. and rear head rest also working, remaining all stop, central lock, lumbar support, petrol lid all stopped.
i thought pse pump have is bad, I removed from the trunk and i checked motor is working fine, Motor only work when i press trunk button from key or driver door. If i press central lock motor not moving or working
i removed the fuse of the pse pump from real passenger right down side, Still not working only trunk works, what will be the issue?
i am confused why only trunk works. Why other system not working?even i cant hear the pump sound,sound only comes whn i press trunk button
by 2023, the lines going from and to the PSE drunk pump have leaks by now. there are repair kits instead of a full line like at dealer. however,
i dont know how to test each circuit, do I just pump some vacumm on each line?
I got similair problem, but if i use trunk button a fuse pops
in your case the pump is shutting off the trunk for a reason most likely a leak
