2006 S430 cranks but will not start
Old Jul 28, 2023 | 10:52 AM
Erizz23's Avatar
2006 S430
The car has been running perfectly fine and I replaced the battery last January. I went to start it last morning and it cranks over fine but just won’t start. Worth trying to clean or replace the MAF? No check engine now or before it happened.
Old Jul 28, 2023 | 03:30 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
Why don't you learn how this forum works; start at the top of the page and then look for your problem discussion.
Stop changing parts unless you have identified the problem!
could be fuel, ignition, electrical ..........
Fill in your model and specifics
Old Jul 29, 2023 | 12:50 PM
wallyp's Avatar
2003 S500 2007 GL450
Crank position sensor is more likely than the MAF. You need to do some diagnostic work before loading up the parts cannon.
Old Jul 30, 2023 | 12:37 AM
tusabes's Avatar
Mercedes
When was the last time it started ? The day before? Or had it been sitting unused for a while ?
