Offset for S-Class??
Old Nov 21, 2004 | 11:25 AM
dtxmob's Avatar
2000 S-Class
Please help just want to know if these offset will fit our S-class MB 5/112 OFFSET 35MM FRONT AND 31MM REAR ?? Thanks for all the help!
Old Nov 21, 2004 | 12:14 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
sorry, those will not fit properly unless you want the wheels to stick out out beyond the fenders. I hope not. Good Luck!
Old Nov 24, 2004 | 05:40 PM
fkong777's Avatar
07 GL450, 91 NSX, 12 Prius
Most S-class aftermarket wheels have about a 35mm offset.
so with your spec they are just about 5mm off. Which is all of a 1/4". they should fit.
Test fit them. and let the car be on static height and use a yard stick to see if the wheel will stick out or not.
Old Nov 25, 2004 | 11:55 PM
E55 KEV's Avatar
Veteran: Air Force
The proper offset really depends on the width of the rim. Mostly 7.5" rims have an offset around 35. Most S-Class rims in 8.0, 8.5, 9.0, 9.5, etc. have offsets around 45.
Old Nov 28, 2004 | 04:38 AM
Lexino's Avatar
too many to list
i was buying 19" AMGs 2 piece rims and the offset was 44 front and 46 rear so i called up MB to find out if they would fit and they said that it would and that is whats recommended by MB so i wouldnt suggest 35 front and 35 rear because it might be asking for trouble. also your warrant wouldnt cover if you break something
