Loud clunking sound from rear when going over road turtles... ABC Valve Block?
Old Dec 20, 2024 | 04:10 PM
Fried Chicken's Avatar
2005 S500 Designo
Took the S500 for a test drive; window open, enjoying life. When going over road turtles (those yellow reflective markers) I noticed a loud sort of clunking from the rear (noticed on the outside of the vehicle, not the inside).
It doesn't always appear when going over bumps but road turtles seem to trigger it. It sounds a bit like loose heat shielding, but a cursory check didn't show anything like that.
I've also noticed the rear starting to sag slightly when sitting, but not all the way down, just more than it used to do.
Could this be a bad rear ABC valve block? Anyone have these specific symptoms? Anything obvious to check before I go through the chore of rebuilding the valve block (already have a kit handy)?
Old Dec 20, 2024 | 05:12 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
clunks *over turtles only*
I have the exact same thing in the front specifically with those turtle reflectors...
I attribute it to compromised Sway Bar bushings.
Old Dec 20, 2024 | 05:43 PM
2005 S500 Designo
ABC cars don't have sway bars aahhhh
Old Dec 20, 2024 | 10:10 PM
that's good to know: your ABC handles the anti body roll
​​​​​.... I noticed your dislike for AGM's being a scam.
​​​​​​My first one lasted over 10 years, twice as long as a flooded type
Old Dec 21, 2024 | 12:43 AM
2005 S500 Designo
The old ones are built better, the new ones are all crap. There are like three manufacturers worldwide. They cost significantly more than flooded. If they run dead even once they're toast. They can't be revived through electricity, nor through fresh acid or water.
Old Dec 21, 2024 | 01:49 AM
I don't think any lead-acid survive deep discharge without building up internal resistance from plate sulfation be it flooded or gel electrolyte.
Cell balancing helps recover from deep discharge to some extent.
I find the Mercedes "drain while parked by CAN-B" to be abnormally aggressive at draining any type of battery flat. It's best to use a CTEK or equivalent float charger.
