General question and if u can help files needed to program W220 s500 2005
Old Jan 5, 2025 | 07:27 AM
Mblucks's Avatar
Well I drive a 05 s500 w220.175 7 speed trans which am currently trying to figure out right now
Ok well first off I wanna say in wat year did they came out with the vgs3 and if a 05 s500 was equip originally to the transmision if not I would like to know because I seen a thread that the vgs3 came out in 06 07 if am not mistaken and the reason I say this is cause I remove my cp and it was a vgs3 but I been reading on how to program and wat not and came across that the vgs3 was made after of so there couldn't be a vgs3 on there in the original so now I neeed to determine wat software originally came in to program it any help I installed the vgs2 module can some one help me verify wat software I need to be running please my Vin is WDBNG75J45A448673 please help I have the topdon smart and t ninja box on the way I just need to see wat software am running and if am correct with my assumption that it was a vgs2 on there originally thank u
Old Jan 6, 2025 | 01:59 AM
Mblucks's Avatar
Ok well I have the topdon smart with the t ninja box coming in a couple days I know that will do it can u give me a step by step on it and befor that I need to fix the no com with transmission issue first pin 6 &14 say that's the cam hi and cam low and it sapose to be at 60ohms right it's it true and I did it right it's at 0 so there is a ground issue right how do I go about that first
Old Jan 6, 2025 | 05:02 PM
Mblucks's Avatar
That's my question were do I get or start looking for the software cause the original conductor plate broke and I can't comunicate with trans at the moment and actually looking into right now with mutimeter but need like a cheat sheet on wat am looking for u know I know wat I need to do and have wire diagram but on how to read voltage or oms and all that don't know we're to place them at u know wat am saying and I ordered me a topdon smart with the t ninja box that will be able to do all the programing and also I seen a video of someone getting the file from the ecu and then flashing it to the conductor plate is that possible like I seen it but idk cause I can't read the original it broke any thoughts
Old Jan 6, 2025 | 07:19 PM
tusabes's Avatar
Mercedes
Programming conductor plates is not a diy task
take it to dealer or independent who has capability to do it
