Shifting issues
Old Feb 4, 2025 | 10:14 PM
texasplayer's Avatar
Shifting issues
Have intermittent shifting issues where it won’t show on the display what gear it’s in. When it does this it won’t go past prob 2nd gear and won’t go back into park. Have to turn off in neutral to be able to get into park.
I cleared codes from previous time and only code I saw under transmission was
130 CAN Communication Disturbed: Electronic Selector Lever Module
what does this mean?
Old Feb 5, 2025 | 08:51 AM
wallyp's Avatar
2003 S500 2007 GL450
Probably a failed module, or a poor connection, or a broken wire on or near the shift lever assembly.
Old Feb 5, 2025 | 05:13 PM
It’s weird it happens randomly - can go 10 times before it does it again.
Would the module need to be programmed? Mine is a 2000 s430
Old Feb 6, 2025 | 08:54 AM
wallyp's Avatar
The shift lever module is locked to the VIN, as it is one of the four "theft relevant" units (Shift module, ESI, ECU and key). Otherwise, it needs no programming.
Old Feb 7, 2025 | 08:43 PM
Fried Chicken's Avatar
2005 S500 Designo
Everything he says is correct.
I just fixed the issue in mine: a "failed module" is actually one of two things: either a failed solder joint or failed electrolytic capacitors on that PCB (inside the shift module).
The intermittent behavior suggests it's the electrolytic capacitors going bad, a problem that's unfortunately only going to get worse until the car refuses to even start due to EWS not getting the right signal from the module (The shift module is linked to the anti-theft. Mercedes will not sell a virgin part unless they themselves install it, meaning open up your wallet for the dealer to do the job).
Workarounds include: PCB board repair including replacing the electrolytic capacitors (what I did), sending it off to someone who does this repair (I forgot the name but a company does this), buying a "virginized" unit where new memory chips have been installed into a parts unit (no longer an option as the guy that did this is retired and when I was looking they didn't have a replacement), or transferring the memory chip from your existing module's PCB to a new module's PCB (not recommended as it'll probably fail soon as well, unless the electrolytic capacitors are also replaced and some solder connections reflowed).
Old Feb 8, 2025 | 08:13 PM
Thanks for info!
did you do the fix yourself?
Is cleaning the tcu connections worth a try?
A weird thing is that as soon as I put in a new car battery - the times it does it is a lot lot less!
so if I’m able source a new one - I wouldn’t have to program it? Would be plug and play?
https://www.shopmbpartsnow.com/oem-parts/mercedes-benz-center-gearshift-2202673324?origin=pla&gad_source=4&gbraid=0AAAAAqW fWcLar5lmgE50xidio4mDZER4I
Old Feb 9, 2025 | 11:25 AM
wallyp's Avatar
The TCU has nothing to do with displaying the shift lever position - that is mechanical/electrical from the shift lever assembly.
If you are asking about sourcing a new shift lever module - Again, the shift lever module is "theft relevant", is married to the VIN, AND must be matched to the other "theft relevant" units. No, you can't program it. No, it is not plug 'n play.
Old Feb 10, 2025 | 11:34 AM
ah!!! Thought if I bought a new virgin part directly from Mercedes or one that was flashed clean - that I wouldn’t have to have it programmed!!!
Old Feb 10, 2025 | 12:53 PM
2005 S500 Designo
To be clear, what's the year, make, and model of your car?
If you have the 722.9 transmisison, everything said in this thread applies, if you have the 722.6 5-speed then the issue is something else.
Re: 722.9: Mercedes will not sell this part to you without they themselves installing it. You will have to take it to a dealership to have this done. They do this because it's linked to the anti-theft. Their logic: if they let these parts get out into the wild, it would open up an avenue for thieves to bring stolen cars back on the road.
Old Feb 10, 2025 | 01:29 PM
I have a 2000 Mercedes s430
Old Feb 10, 2025 | 02:35 PM
2005 S500 Designo
Oh... then you have the 722.6 5-speed, right?
Old Feb 10, 2025 | 03:28 PM
I believe so! Does that now change the advice on what I need to do?
Old Feb 10, 2025 | 04:12 PM
2005 S500 Designo
Yes.
The 722.6 transmission shift linkage can be ordered and swapped out from the dealership.
It's still possible the failure you're describing is fixable with a capacitor swap/board repair.
There is a different failure mode for the 722.6; I remember seeing it on a w211...
At least I'm pretty sure all this is the case with the 722.6 in the w220.
Old Feb 10, 2025 | 04:45 PM
shift linkage? U don’t think its the shift lever module? If its the shift lever module - since it’s a 722.6 version - would that need to be programmed or not?
fixable with a capacitor swap/board repair - who generally would do this type of repair? What should I google?
Old Feb 10, 2025 | 07:44 PM
wallyp's Avatar
The SHIFTER MODULE in the earlier W220 - including yours - IS a THEFT RELEVANT assembly, and what you have read several times applies.
I'm out.
Old Feb 10, 2025 | 10:51 PM
tusabes's Avatar
Mercedes
You can swap 4 parts from another car - key shifter ecu and ignition switch . They sell matched sets on eBay or car being parted out . If you swap all 4 parts taken from the same donor car then no programming needed
most people sell the 4 matched parts for $350-400
otherwise you have to buy new for $1000 plus pay Mercedes to program
Old Feb 11, 2025 | 08:53 AM
2005 S500 Designo
I'm out.
wallyp knows.
It seems it is.
I'm not sure if it uses the same shift linkage as in the 722.9. If it does, you can find pictures and what successfully worked for me in this thread here:
https://mbworld.org/forums/s-class-w...ml#post9083676
