immobilizer problem!!!!!!!
Old May 15, 2025 | 05:48 PM
12master's Avatar
hello, after having a problem with the shifter throwing a code, I put a used one without doing the proper research, and now the vehicle activated the immobilizer. so I put the original shifther back, and the immobilizer is still activated and i don't have a way to clear it, as a consequence, ignition key turns but no crank. any ideas as how to proceed?
Old May 17, 2025 | 01:45 PM
Fried Chicken's Avatar
2005 S500 Designo
What code?
It could be the capacitors in your shift module have gone bad.
Old May 20, 2025 | 03:05 PM
e350forme's Avatar
fleet
you need some sort of scanner to access and reset the shifter module
something mercedes specific for like 100-200 bucks right?
shifter faults come up on my scanner, it does an in depth test of everything in the car even the heater wiper fluid nozzles
