Stock Brake Discs on 2003 S600
Did Mercedes spec left brake discs to mounted all around? If that is the case, the discs mounted on the right side of the car will not cool properly because are they designed for the left side of the car.
In all honesty, you will probably not notice a problem unless you track the car or use your brakes very hard for extended periods.
When it comes time to replace my disc's, I will look at Non OEM entities such as Brembo, Stop Tech, etc. with aluminum hats.
