S 430 BLOWER MOTOR INTERMITTEN PROBLEMS
If by main auxiliary fan you mean the radiator fan, it does not blow air into the car.
The secondary air injection pump has no connection at all with the HVAC system.
Check the blower fuse.
The HVAC blower is powered through an attached electronic control unit. You can access the blower motor fairly easily (Google or DuckDuckGo are your friends). You can then remove the electronic control unit and plug the heavy red power wire directly onto the fan motor. If the motor runs, the problem is likely to be the control unit. If not, the problem is likely to be the motor or the power to the red wire.
Hey wally good to hear from you . I disagree but as always I value your expert opinion and experience. I still think the motor blower resister was blown during the jump start . I have changed the 40 amp fuse to the heating and ac motor already along with the other two 40 amp fuses next to it . I'm going to look into a motor blower or controller unit I'll keep you posted .
wyrschper236@gmail.com
