No crank 2003 s600
Old Mar 4, 2026 | 10:01 AM
goodwin3024's Avatar
2003 s600, 2005 e320, 1982 240d
No crank 2003 s600
Got my s600 out of the garage today, had a dead battery but replaced it and drove it about 20 miles. Got home and left it outside for about an hour (no rain 85 degrees) before attempting to put it back in the garage but no it won’t crank. Tried all three keys and same thing. Battery is good and I’ve tried both the batteries from my Porsche and c class with the same result. Key will turn everything comes on but car still won’t crank even tried a 12 hour sit for the battery being disconnected. No water intrusion is possible as this car has been stored indoors since 2003 and hasn’t even been moved out of the garage since June of last year. Any ideas?
Old Mar 5, 2026 | 07:23 AM
JohnLane's Avatar
222 S-65
Are you able to access the starter?
If so, verify power to the large lead from the battery. 12v there? If not find why.
Pull small lead that triggers the starter. Jump from power to pin for small lead. Cranks?
If so it is time to plug it in to Xentry.
