01 s500 Horn not working
Old Jan 3, 2005 | 08:41 PM
jjrho's Avatar
2001 s500
inputs pls. 01 s500, only 1 horn working... the same one the dealer fixed/replaced under warranty a year ago... i'm too busy to goto the dealer....
1. is there separate fuse for each horn?
2. where are the horns? can i check for physical wiring issue?
3. the high tone is out....where's this horn? i'm hoping it's just a wire pullled out... if it's bad again, out of warranty, so i may need to reinstall/fix it....
any inputs would be appreciated...
o/w, the cars doing well...60K miles....solid car...
01 s500 amg, 04 lights
jjrho@adelphia.net
Old Dec 7, 2021 | 06:00 PM
davebmoore's Avatar
2001 Mercedes S500
jjrho@adelphia.net
Did you ever receive a response to this? I have a 2001 S500 with one horn not working (high tone 500Hz on left front). Are there separate fuses or just one? Thanks for a response.
Old Dec 7, 2021 | 06:49 PM
wallyp's Avatar
2003 S500 2007 GL450
The post was 17 years ago, and he hasn't been seen in 14 years...
One fuse, and the horns are known to fail. Harbor Freight sells a pair of horns that work very well in the W220, and they are pretty cheap.
