couple quirks with my new S550...anyone else experience the same?
too many cars
I've had the car for about 1 month now, and have about 2000 miles on her. Two things i've noticed.
1. the display for the radio/nav etc will sometimes flash on and off when i first start the car...does this for about 5 minutes before it stays on
2. after i park the car and turn it off, sounds like there is liquid dripping onto a hot surface, creating a sizzling sound (a/c has been off)
3. when coming to a stop, at about 1 mph, the car kinda shudders, like the tranny is searching for a gear or something..
anyone else see the same things?
McLaren 570S, G12 BMW 750Li, GLE63s AMG Coupe
I have not had issues 2 and 3....regarding problem 1...i have not noticed any screens flashing etc....which screen is it the command central screen or the speedometer computer screen?
98 Ford Explorer Limited, 2007 S550 LE
The only thing I have noticed about my car which is somewhat similar is when the car is idling it sometimes shutters a little, as if it's searching for a gear.
1 Post
4 wheels
Originally Posted by jl88
The hazards of owning a first model year german car..
/shudders
/shudders
too many cars
keep in mind that these little quarks do not make the car any less desireable. the only thing that i am getting rid of the car for is the new S65 when it is available.
there is always give and take when it comes to this stuff...
my w221 s500 doesn't shudder but my w211 E500 did...at very low speeds...as if it was searching for a gear...but that had the 5-speed not the 7G tronic
The other problem the just started to happen is after reversing the passenger side rearview mirror does not return to it's original position. I have to move the mirror backup myself.
S500/W220/2000
2010 E350, 2007 S550 - SOLD, 2007 ML350
Here is something else I noticed:
When you drive it for the first 10 minutes or so, you can hear a slight popping sound all around the vehicle. I am not too sure what it is. Anyone else notice it?
S500/W220/2000
S500/W220/2000
I can try to help a lil, these cars are pretty new but some of the things you mentioned sound familiar
1. had this happen on other cars, could be normal for the new command system, its possible there is a flash for it
2. most likely the catalysts breaking in, or something else breaking in, pretty normal for new cars tho
3. im going to assume it is a 722.9 transmission, these are adaptive to your driving habits so give it some time, if it goes away then great, if it gets worse and worse and actually starts kicking hard you have a problem, but 9 times out of ten its brand new and still adapting
hope that helps
S500/W220/2000
05 ML350, 85 300D
1- not normal- sounds like a faulty hard drive (seen a couple but way better than the first command when it came out)
2- hard to say without hearing it- are you shutting the AC off completely? If so, why? (But thats a different question)
3- it's the 2-1 shift, should get better , if not then it needs one of, or a combination of - software, valve body, new spring clip in the B1 piston internal to the transmission
too many cars
thanks for your help. gonna bring it in to the dealership this week and have them work out the 3 (sorry..not 2) quirks...will report back on thier findings...
