MBUSA W221 Bulletins to date
Old May 26, 2009 | 06:29 PM
  #76
konigstiger's Avatar
'71 Pinto
DTB P-B-77.20/80 APR09 up to VIN A005500 sunroof shade slides open/close while braking or accelerating, the cause may be that the clamping force is too low. To resolve, the sliding shoes will be replaced.
P-B-32.50/79 MAY09 All 216 & 221 vehicles equipped with Active Body Control (code 487). Knocking noise from under the floor area when driving over bumps or stationary, the hydraulic lines will be inspected for proper routing. They must not contact the body and must be free of tension.
Old Jul 30, 2009 | 07:52 PM
  #77
'71 Pinto
Service Campaign 2009060006 JUL09 panoramic sunroof may not close smoothly dealers will update software, 134 vehicles affected.
LI62.25-P-047124 JUL09 cracking noises from the area of the IC/firewall when cornering, during throttle lift-off and uneven roads, wax will be applied to spot welds.
LI91.10-P-047255 JUL09 dynamic seat (432) VIN A285851 up to A286075 crackling noise to lower area of backrest when sitting down or adjusting the backrest, clip to felt support of multicontour insert is touching the backrest shaft and will be removed.
LI54.65-P-047195 JUL09 reversing camera inoperative line can kink or break at the locations on the hinge and rear shelf in trunk and will be replaced.
LI77.20-P-047416 JUL09 noises when raising/lowering sunroof, panel needs adjustment.
Old Aug 31, 2009 | 04:46 PM
  #78
'71 Pinto
LI54.21-P-047601 AUG09 Passenger airbag off lamp, switch illumination of upper control panel (UCP), instrument panel and light switch flicker briefly sometimes with brief display “Parktronic Currently Unavailable” although functioning correctly dealer will update UCP software.
LI54.70-P-047828 AUG09 “Distronic Inoperative” displayed faulty charge level of backup battery shuts down Distronic function dealer will charge or replace battery.
Old Sep 28, 2009 | 09:06 AM
  #79
bhartv's Avatar
Does anyone have an idea of where I can find the service bulletins for the UK please? Thx
Old Oct 1, 2009 | 05:44 PM
  #80
'71 Pinto
Service Campaign 2009080004 SEPT09 Temporary interruptions of the picture of Night View Assist system may occur, dealers will update the software. Approximately 27 vehicles affected.
LI91.10-P047254 SEPT09 Complaints concerning right seat adjustment up to VIN A258661, replace adjuster, control unit bracket and seat cushion parts kit.
Old Oct 29, 2009 | 05:01 PM
  #81
bhartv's Avatar
Old Oct 29, 2009 | 05:05 PM
  #82
hawk20's Avatar
E220cdi Estate Avantgarde March 2008
We need an English version of the great Konigstiger. Not available as far as I know.
Old Nov 2, 2009 | 04:45 PM
  #83
'71 Pinto
Service Campaign 2009090005 OCT09 - MY10 horn may not actuate at all corners of the horn pad. Approximately 40 vehicles affected.
LI91.25-P-048132 OCT09 – VIN range A299864-A302080 multicontour seat fails during air release procedure, system becomes operational again after an ignition restart SCN coding will be performed to driver and passenger dynamic seat control unit.
LI42.45-P-047542 OCT09 – start abort or it may not be possible to start the engine when using Keyless Go, update ESP control unit software.
LI42.47-P-048216 OCT09 – “ESP Defective Service Required” with vehicle at stand still, ESP warning lamp flashes (yellow triangle) and transmission cannot be shifted out of park, vehicle can lock itself automatically and/or with ignition on and vehicle at standstill a speed of 160 MPH is displayed in the IC. Rpm sensors will be replaced and ESP control unit flashed.
Old Nov 29, 2009 | 08:47 PM
  #84
Roger lin's Avatar
W221
thanks for your information , It very useful TSB ,but where can i download them ??
Old Nov 30, 2009 | 09:06 PM
  #85
'71 Pinto
Owners can subscribe to STAR TekInfo http://www.startekinfo.com/StarTek/ or PM me to receive a copy for the bulletin of interest – include your email address.
Old Dec 1, 2009 | 03:29 PM
  #86
'71 Pinto
LI32.50-P-048280 NOV09 humming/howling noise from ABC suspension up to approximately 2000 rpm particularly noticeable at about 1400 rpm replace pulsation damper at pressure supply valve block or tandem pump (ABC-PLUS).
LI91.30-P-048290 NOV09 noise from active multicontour backrest with seat ventilation switched on fix pneumatic lines in place.
Old Dec 1, 2009 | 11:26 PM
  #87
Roger lin's Avatar
W221
__________________
Great !!! thank you so much for your contribution ,my friend !
Old Jan 5, 2010 | 03:30 PM
  #88
'71 Pinto
LI82.10-P-048587 DEC09 as of model refinement up to production 11/09 rattling noise from front end, headlamps will be replaced -- self test; with the hood open with engine running and lights on, rock the suspension rattling is clearly audible from the headlamps.
LI42.10-P-048624 JAN10 – 221/216 except AMG rear wheel brakes squeal dealer will clean lining slots, replace pads and apply brake paste under warranty.
Old Jan 19, 2010 | 05:34 PM
  #89
RajwanyS550's Avatar
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
could u please tell me if there is anything out there for 2010 S550 with massage seats. mine makes air leaking noise intermitantly. dealer as usual says its normal. thanks in advance
Old Jan 24, 2010 | 10:51 PM
  #90
anybody?????
Old Feb 11, 2010 | 02:45 PM
  #91
CLIFF4781's Avatar
2007 S550
Is this brake problem apply only to the first 12 months or is it an additional bulletin to fix squeaking brakes during the 4 yr warranty? My dealer says it only applies to the 1st 12months and won't replace the pads. They also say that they aren't familar with the number LI42.10-P-O4862424 JAN10. Where did this bulletin come from?
Thanks, cliff4781
Old Feb 11, 2010 | 03:33 PM
  #92
'71 Pinto
Originally Posted by CLIFF4781
Is this brake problem apply only to the first 12 months or is it an additional bulletin to fix squeaking brakes during the 4 yr warranty? My dealer says it only applies to the 1st 12months and won't replace the pads. They also say that they aren't familar with the number LI42.10-P-O4862424 JAN10. Where did this bulletin come from? Thanks, cliff4781
Check PM
Old Mar 2, 2010 | 01:03 PM
  #93
'71 Pinto
Service Campaign 2010020001 FEB10 massage function of the front seats may not have been coded to specification in seat control modules, software calibration number (SCN) update to left & right dynamic multicontour seat control modules will correct this condition. Approximately 63 vehicles are affected.
LI46.20-P-048871 FEB10 rattling or dull knocking noise coming from the area of the steering system when driving over rough road except 4matic – steering system mounting bolts, play between thrust piece & steering rack, and/or outer/inner tie-rod ball joints will be checked and rectified.
Old Apr 1, 2010 | 06:51 PM
  #94
'71 Pinto
LI54.30-P-049039 MAR10 – MY10 221 & 216 all indicator lamps in the instrument cluster may light up after engine start and various fault messages appear, dealer will update IC software.
LI54.10-P-049241 MAR10 – 221 Hybrid start/stop function the engine starts up again automatically after vehicle comes to a complete stop and/or charge level is insufficient ground line between the DC/DC converter is inadequate.
LI54.10-P-049295 MAR10 – 221 Hybrid will not start, if battery drops below 7V for longer than 5 seconds monitoring function logs various fault codes which prevent the engine from starting.
Old May 9, 2010 | 09:34 PM
  #95
TDwayne69's Avatar
2012 CLS63 PP
One Button Push To Open and Close The Sunroof
I know when I had my BMW 750LI, I could push the sunroof button once to open or close it, but on my S550 I can push button once to open it and in order to close it I have to hold the button. I don't know if this is a true issue or not, I may just need to get it reprogram? Does any one else have this same issue?
Thanks,
Tony
Old May 10, 2010 | 01:46 AM
  #96
Jan AMG's Avatar
The best or nothing
Thanks,
Tony
Tony, I have the same issue. When I had the CL63 AMG, it did it automatically.. I'm sure 2009+ S-class has it automatic closing too.
Old May 10, 2010 | 03:14 AM
  #97
QuadBenz's Avatar
Mercedes, Porsche, BMW, Tesla
Thanks,
Tony
On our previous S550, it wasn't necessary to press and hold the switch to close the sunroof.
Old May 10, 2010 | 09:48 AM
  #98
CL55_Serge's Avatar
CL65 AMG , white S550 Sport w/ white Giovanna 22s, wild custom chopper
Tony,
I think I had this issue after picking my '07 at the auction. I believe there is a position sensor resynchronization procedure involved. Have you tried opening the sunroof and then holding the button down to close, then once closed hold the button down in closing position for something like 7-10 seconds? I think I got the condition to clear up after I did that and the closing of the sunroof became a one-touch operation. Certainly the dealer would know my way doesn't work.
-Serge
Thanks,
Tony
Old May 10, 2010 | 05:05 PM
  #99
TDwayne69's Avatar
2012 CLS63 PP
Hey Serge,
I tried the resynchronization procedure, but it didn't work so I guess I'm going to have to head to the dealership.
Thanks,
Tony
Originally Posted by CL55_Serge
Tony,
-Serge
Old May 10, 2010 | 06:06 PM
  #100
'71 Pinto
If attempt to synchronize fails, dealer may need to clean & lubricate for express-operation to function normally.
File Type: pdf
