Socket for lug bolts on S550 wheels
Old 09-06-2012, 08:15 AM
marthyh's Avatar
S500
Have rxd this today ,not so tight on the bolts as I expected; it will do the job I guess.
Old 09-06-2012, 07:14 PM
ultgar's Avatar
Message deleted
Old 09-06-2012, 08:46 PM
S_G7's Avatar
2007 S550V4
Originally Posted by S_G7
I tried a regular 17mm thin wall and it barely fit the lugs. I also tried an 11/16 and that fit much better than the 17mm, but there was a little play. The 11/16 is definitely a better choice than a regular 17mm, but I look forward to the exact fit of the NSB.17.
I ordered brand new lugs from Amazon and they arrived today. For anybody who needs new lugs they can be found here:
Amazon Amazon
. These are the OEM lugs, they arrived in bags with the Mercedes part number 000-990-54-07.
I re-tested the fitment of the 17mm and 11/16 sockets on the brand new lugs and both fit fine (there is minor play with the 11/16). It appears that if the lugs aren't damaged or worn out, the regular sockets will work, but are more likely to distort and strip the lugs over time. I'll try the NSB.17 when it arrives.
Old 09-07-2012, 08:55 AM
ultgar's Avatar
I ordered brand new lugs from Amazon and they arrived today. For anybody who needs new lugs they can be found here: http://www.amazon.com/gp/product/B00...ls_o00_s00_i00. These are the OEM lugs, they arrived in bags with the Mercedes part number 000-990-54-07.
I just spoke with my local Worldpac salesman and they've sold 1900pc of these Febi lug bolts in the past year. I think Mercedes has dropped the list price (now showing as $7.50ea) because of the high incidence of damage with the use of impact guns at their shops.
Some owners keep this 24" breaker bar with convex socket in their trunk for emergencies........
COUPCONNOISSEUR (05-24-2020)
Old 09-14-2012, 01:16 AM
xxGenericSNxx's Avatar
99 ML430, 01 CLK55, 07 R63, 15 E63 Wagon
I got the socket and I'm very happy with it. I've even showed it to some techs and head of parts at my local MB dealer and they have some interest.
BTW, I was surprised that it's actually more loose on my bolt than a 17mm socket. There's more wiggle room. But I like how it grabs on the center rather than the edges lessening the opportunity for technician error.
If this is made for the Maybach tool set, why isn't there a Mercedes-Benz part number?
Old 09-14-2012, 08:03 PM
S_G7's Avatar
2007 S550V4
I also had great results with my NSB.17 socket as well. I had all of my lug bolts replaced with new ones and there is no signs of stripping or damage. Highly recommended.
Ultgar, is the free shipping code one per account? I was thinking about ordering another one for backup.
Old 09-15-2012, 02:16 PM
  #32
mb1000's Avatar
S550 4MATIC W221, W222, Lotus Elise
Don't buy bolts, fix them.
If you look at the bolt closely, the head has the stainless wrapper on bolt and it is soft. The problem is that the wrapper out of shape after uses. You will find new ones soon to be out of shape again.
There is an easy way to re-shape the head which I did. Here is how:
Find a few short wood blocks and a rubber hammer, or wood block instead of. Insert bolt all the way in to socket.
Then put the bolt and wrench all together, one end on a wood block to keep some angle. Using a rubber hammer or a woodblock, hammering heavily sidewise between bolt and wrench. Rotating the bolt and keeping hammering. After a few rounds, the head of bolt will be in perfect shape again.
Hope this can save you a few $$.
Old 09-15-2012, 03:22 PM
  #33
mb1000's Avatar
+pic
Old 09-16-2012, 11:41 AM
  #34
ultgar's Avatar
Message deleted
Old 09-16-2012, 11:49 AM
  #35
ultgar's Avatar
Not sure it was made for the new lug bolts as the socket has been around since the mid-90's. I used to sell it to BMW owners as a safer alternative to the standard 17mm hex since the convex socket grabbed the bolts on the flats rather than the corners. Then in Nov 2007, I was contacted by Mercedes of Manhattan (NY) looking for a Facom socket (the NSB.17) that came in their Maybach tool set. Its only recently that car owners have been buying these for themselves. SD
Old 09-16-2012, 04:33 PM
  #36
S_G7's Avatar
2007 S550V4
Originally Posted by ultgar
You can order as many as you like this month with free shipping. There's also a 10-pack pricing ($300 for 10pc) which also qualifies. SD
When I tried a second order, the free shipping code doesn't apply.
Old 09-16-2012, 04:37 PM
  #37
S_G7's Avatar
2007 S550V4
+pic
Thanks for sharing. Do you have a picture of the lug bolt head, after this process?
Old 09-16-2012, 07:53 PM
  #38
mb1000's Avatar
I did not take pic after. Anyway, bolt looks the same as before but much better fitment with socket. The feel is the same as new one. Also, you don't need to use much force to punch. The wrapper is pretty soft.
Old 09-17-2012, 10:46 AM
  #39
malahhaor's Avatar
06 Carrera4
Use coupon code NSB912 to credit back the $10 flat rate shipping on this item. Code is good for the month of Sept. Delivered price is $35.00. See http://www.ultimategarage.com/shop/p...oducts_id=1425 . This is the same socket (by Facom) that comes in the factory tool set.
Tried to checkout through PayPal and coupon code was not accepted. do i need to use website checkout for the coupon to work?
thanks
Old 09-17-2012, 10:55 AM
  #40
ultgar's Avatar
thanks
Put the order through and I'll issue a $10 Paypal refund before shipping the socket. SD
Old 09-17-2012, 11:02 AM
  #41
malahhaor's Avatar
06 Carrera4
Done, order 6545
thanks much.
Old 12-29-2012, 03:30 PM
  #42
ultgar's Avatar
$5.00 shipping credit on Wheel Socket
Use code nsb5 at checkout ....this will reduce the effective shipping cost to $5.00 for this socket. See http://www.ultimategarage.com/shop/p...oducts_id=1425 .
Discount will be applicable through 12/31/13. SD
Old 04-21-2013, 10:12 AM
  #43
new550's Avatar
2015 s550v4
Anyone find a replacement bolt for the "flower-head" lug bolts that came on these cars? I have too many lugs that are stripped or rounded and would just like to replace them all with a more standard bolt....
Also, They appear to be a two part "bolt with a cap on top"...anyone remove the cap and see what is underneath? Maybe its that simple?
Old 12-07-2013, 08:50 PM
  #44
AG6
AG6's Avatar
13 GL550
Placed my order for NSB.17 for my W221.
Old 12-13-2013, 10:53 AM
  #45
brianw430's Avatar
'11 S550 4Matic, '12 SL63 AMG, '13 ML350, '16 AMG GT-S Ed. 1,'03 Ford F-250
I had one bolt stripped by the local dealer. They had not heard of the special tool to remove them, and viola, stripped it flat. Technician said it is simply a 6 sided 17mm socket. Just ordered the special socket to have and will share this with dealership. They showed me the invoice for a new lug...$5.45/bolt.
Old 12-13-2013, 10:17 PM
  #46
natcahd's Avatar
2011 S550
My order is scheduled for delivery Monday. I didn't want to take any chances. used the coupon to reduce the shipping price. Ultgar shipped very quickly.
Old 12-14-2013, 01:02 PM
  #47
AG6
AG6's Avatar
13 GL550
Got the socket. Fits well.
Old 12-15-2013, 01:28 PM
  #48
castro69's Avatar
S350 w221
This is not the right tool. It will not protect bolt heads better than a regular hexagon socket. The right tool, you can see here:
http://www.ebay.co.uk/itm/WHEEL-NUT-...item53fce59fee
Old 12-15-2013, 03:28 PM
  #49
natcahd's Avatar
2011 S550
Damn Castro where were you a week ago? LMAO
Old 12-15-2013, 04:49 PM
  #50
Atcpup's Avatar
S550
Now I order, thanks Castro!
Quick Reply: Socket for lug bolts on S550 wheels
