enable command DVD while moving for passanger
I'll probably chime in on this about Wednesday or so to give an update.
My car, being a 600 with every feature known, was most likely going to be an affected model. So, I would suspect it would be good to call Rob and let him send you a newer revised module as mine works great.
Now I run a S-class demo dvd while I drive... almost as a screensaver.
I will keep my eye on it to make sure there are no issues.
Where can I get a S-class Demo dvd?
I have been out of town for a while but drove my car for the last couple of days and the problem of COMAND blanking out for a couple of seconds persists. I shall give Rob a call. Although I just hope he can solve the issue as unfortunately I do have all the features that Merc could provide like Distronic plus, drive dynamic seats, night view assist, blind spot assist, rear seat package, etc etc and just hope none of these are interfering with the midcity module.
Thanks so much for all your informative posts of having been able to solve the issue finally.
Anyway, just give them a call and Im sure they will get you an updated module.
THANK YOU ALL ONCE AGAIN. Truly appreciate all the advise and help. Warm regards....
Side Note- Just got a Smart Cabrio to augment my S. Love it!
Is this still your first module you're referring to, or have you already gotten it swapped out and it still does not work on the second module?
One other issue I wanted to check with you, as I did ask the forum earlier but we never got a solution, so I guess most of us are living with this problem..... In the older model of S class (upto 2006 shape), the volume of radio, Sat, CD, etc would go down if you were in Navigation mode in the COMAND system. However, in the S class now, if you have your audio or video loud and even if the Navigation is active, the navigation volume continues to remain low. (A) Do you have such a problem too? (B) Wonder if one can ask midcity whether their revised module can do some thing to let the navigation volume take priority? (C) Has there been an upgrade in software/hardware interface that supresses the audio from other devices if the navigation system prompt comes up?
THANK YOU SO MUCH FOR ALL YOUR HELP AND ADVISE. Warm Regards.
