Power door close assist question...
2013 SL 550 (Previously 2012 Porsche Panamera Turbo-S, 2015 Tesla P85D, 2007 S600, 2005 E55 AMG)
I have just noticed that my front passenger power door assist does not appear to be pulling the door shut. My dealer recently put in some new/larger clips to attach the door lining more solidly and I wonder if they turned this functionality off. Is there an easy way to turn this back on? I was wondering if this is something like a child lock switch but I can not find anything in the manual. (All 3 other doors work fine)
Chris
Chris
Chris
Chris
Curious....for what are the new clips in door lining....to cure rattles/squeaking?
My sense from various P boards (new P's are notorious for endless squeaks/rattles, esp on bumpy US roads) is that chasing such sounds w/disassembly of panels, etc often creates many iatrogenic complications....truly is a controversial cost/benefit bet in deciding to try to cure any annoying noises....some of which "self-cure" anyway....
My sense from various P boards (new P's are notorious for endless squeaks/rattles, esp on bumpy US roads) is that chasing such sounds w/disassembly of panels, etc often creates many iatrogenic complications....truly is a controversial cost/benefit bet in deciding to try to cure any annoying noises....some of which "self-cure" anyway....![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
And no, it was not a coin jammed in there. I took it apart several times to make sure nothing had fallen into the mechanism. It just would hang up 80% of the time for over a year.
My SA coincidentedly had received a factory notification that a small batch of cars went through the line with smaller clips attaching the door trim than usual and that in those rare occasions where a rattle has been reported they should be replaced with larger clips.
Mine was one of those cars apparently, the clips were replaced, and the problem has gone away. It was really no big deal - any human artifact of this complexity may have the odd issue that is no reflection on the overall quality or engineering of the product. My SA certainly takes care of me, he genuinely wants to ensure my car is 101% perfect, and keeps me informed about various factory bulletins that might be applicable. (It's like finding a good dentist/doctor etc)
You are right that many issues "self cure". In an adjacent post I mentioned some non-repetitive micro-audible ticks I can hear from the leather on my dash when starting from cold, but these go away after 5-10 minutes. (No doubt temperature adjustments in the materials and as I still have only have 6,600 miles on the clock the material interfaces must still be working in)
Chris
cjf, totally understand....
Am OCD about any extraneous noises in my car (and I typically drive w/no music/radio on, as I enjoy exhaust music....so I more easily perceive any unusual noises given lack of other audio effects)....
Noticed some minor creaking in dash (seemingly from the carbon fiber central aspect of my dash nr climate ctrls) of my current CL63 030 at some ?5-6K mis, but only occurred once/twice on certain stretches of 101 on Peninsula (one of SF's worst fwys) or certain bumpy SF streets....was incredibly annoyed....but the creaking quickly disappeared w/o any attempt at a fix, even on same rds at same speeds....and my CL at 12K mis remains tighter in apparent build than some new AMGs I've recently test-driven....incl CL65 w/<100mis and SL63 030 w/300 mis (that awful Pano roof was creaking incessantly on a bumpy PaloAlto street)...
Def is a difficult bet on when to "chase" such noises and when to let them "self-cure".....hope your dealer seamlessly resolves the door-close issue....
WSH, so what you're saying is that you take your car to a physician when you have certain minor issues and the physician may create even more issues??? ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
I think you may be using "iatrogenic" incorrectly here...but I know what you were trying to say...
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
whoover, interesting guess....
But neither accusation is true
BM24, true, "iatrogenic" is traditionally used in describing medical-related complications, but why not try to adapt an underutilized term to other, analogous situations????
Yes a slight rattle was coming from the front passenger door - but only on rare occasions at a certain speed (40 mph) on a certain type of rough road surface. (We have those in the East Bay!)
Chris
Chris
But My car is older, from late 2006 while you seem to have a 2008 (is that MY or build?) car, if it is a small build, it should not concern these two cars.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Will have to have a look at some sources that describe these issues...
This is interesting because my passenger door (and only the front passenger door) has occasionally some rattle. If I press it from the centre, the rattle stops. I've asked the dealer to look at it when the car was new and again at the first service but I doubt they even noticed it.
Chris
