Wiper blades
Old May 27, 2008 | 09:12 PM
trumpet1's Avatar
2007 S600
Wiper blades
Just wondering how many miles or what time frame that most of you folks are getting on a set of wipers? I'm at 22000 miles and mine are beginning to shudder across the windshield. How much are they for a pair?
Old May 27, 2008 | 09:31 PM
MB Fanatic's Avatar
4 wheels
I think they are about $50 bucks for a pair. Fairly inexpensive IMO.
Old May 27, 2008 | 09:54 PM
konigstiger's Avatar
'71 Pinto
You can mention DTB P-B-82.30/366c the dealer will inspect the blades for wear and replace as needed, thoroughly clean windshield, verify use of correct washer fluid, check washer nozzle adjustment, and if noise persists check and adjust the wiper arm angle adjustment under warranty.
Old May 28, 2008 | 12:03 AM
trumpet1's Avatar
2007 S600
Old May 28, 2008 | 12:04 AM
trumpet1's Avatar
2007 S600
I agree, not bad.
Old May 28, 2008 | 01:37 AM
MB Fanatic's Avatar
4 wheels
Hey does this DTB also cover the CL 216? I have the same problem on my CL63 as described in teh DTB.
Old May 28, 2008 | 02:21 PM
'71 Pinto
Released MAR07 titled "Adjusting Wiper Arms" and addresses wiper chattering/noisy for ALL passenger models.
Old May 28, 2008 | 05:27 PM
AustinGuy's Avatar
'09 S63 AMG
Not sure how well this will work with the MB (although I suspect there shouldn't be any issue)........ RainX!
Works like magic - put it on my wife's GX470 and it's like, well, magic - the rain simple beads off and you don't even have to turn on your wipers no matter how hard it rains.
Old May 29, 2008 | 07:57 AM
trumpet1's Avatar
2007 S600
I've used it before and it is good stuff. Might give it a try. My blades wipe well right now but they shudder across the screen as they wipe.
Old May 29, 2008 | 11:56 AM
AustinGuy's Avatar
'09 S63 AMG
Not sure if RainX will fix the shudder, but logic dictates that it should.
If I were you, I would not jump and put in on my car just yet. Call up your MB tech and ask if the RainX polymers will cause bonding problems with your hitech MB glass
Old May 29, 2008 | 11:40 PM
carsnob's Avatar
2007 S 600 / '06 911 Porsche C4S cab
S classes get free wiper blades exchanged under warranty in the first two years. (At least that's the case here in Canada). It should be the same in the U.S.
Old May 30, 2008 | 07:07 AM
trumpet1's Avatar
2007 S600
Very doubtful. If I can make time, I'll swing by or call my SA and ask. I'd be 100% surprised if they do.
Old Mar 3, 2009 | 10:58 PM
irieblue's Avatar
2007 S550 AMG with ABC
What was the outcome of this? Did you talk to your SA? I am at 17,000 miles and am hearing this shudder... It's more noticeable now that we are having heavy rains in Northern Cali... Did they replace them under warranty?
Old Mar 4, 2009 | 02:31 PM
trumpet1's Avatar
2007 S600
Nope, I had to pay $60 for a pair!!!
They saw me coming I guess.
Old Mar 4, 2009 | 03:10 PM
'71 Pinto
Dependant on the wear status of the wiper blades (not more than 50%) mention DTB S-B-82.30/366d JUL08 adjusting wiper arms, and S-B-82.35/621 maintaining wiping quality / controlling noise for warranty coverage PM your email address if you want copies.
Old May 26, 2009 | 11:49 PM
trumpet1's Avatar
2007 S600
I've made a bizzarre discovery. Many of us have noticed that if we leave our turn signal stalk on intermittent settings that after completing a turn, the wiper sweeps across the windshield one time for no apparent reason. (No rain in sight)
Today I discovered that it does it only after making a left turn if the stalk is left on intermittent postion 1, but if the stalk is left on in the intermittent position 2, the single wipe occurs after completing either a left or a right turn.
Old May 27, 2009 | 12:20 AM
QuadBenz's Avatar
Mercedes, Porsche, BMW, Tesla
I've seen many complain about this, however mine has never done this. It has a couple times randomly on the freeway, but that's just about it.
Old May 27, 2009 | 10:24 AM
softgenious's Avatar
07 S550
I have used this but under certain conditions it will cause your window to fog up...
Old Jun 20, 2009 | 11:25 AM
kyao888's Avatar
C230 Kompressor (Totalled)...just got a 08 E350
RainX
I had the dealer changed the wiper blades about a few month ago. After applying RainX the other day, it cause my blades to shudder like crazy. I thought I needed to replace the blades again but I cleaned it out with regular Windex...the shudder is gone!
I don't know if it is a coincidence but please pitch in if someone else has this problem with RainX.
