Tire replacement
I had replaced the rear right side tire because it was flat and was not be able to fix it. The millage was around 14000. It is the 19 AMG sport package wheel. After I replace that tire, I feel slight pulling to the right side of the road when I drive. It could be the road in NY city or I drove my wife's
X5 since the change because I had been shocked by $550 for the tire.(BMW tend to have less pulling due to the road surface)
My concern is that because I changed right side only even though it's rear, is it OK with balance? I mean left and right balance...
The Service Advisor said it will be fine, but I just wonder the balance is causing slight pulling. The tire pressure is little different when I checked it today. Front 33,31 Rear 32, 34(this is the one has been replaced)
As I can see front right tire is little lower than others and it could be the problem but only by 2.
Any suggestion?
