V1 or K40 install on S550 09
Old Mar 2, 2014 | 09:02 PM
Mike5215's Avatar
2016 C300
I'll get some pics up. I'm guessing the 09 doesn't have a 12v outlet in the glovebox so here's how to run the wire and tap power from the fuse panel on the side of the dashboard. On 2010+ just run the wire into the glove box from here and use the 12v receptacle. (You'll need the V1 hardwire kit or you can make your own using standard R32 phone cable.)
*Forgive the crappy cell pics.
Start where you want the V1 mounted. Pull the forward edge of the headliner down a bit and tuck the wire inside, working toward the passenger door. It's loose and easy to work with.
The A Pillar cover is tight, but you can pry the top edge away enough to tuck the wire inside. Work along the seam from the windshield side to the door jamb side of the A Pillar cover.
This is the easiest run. Just peel the fabric insulating strip away and work the wire underneath until you get down to the dashboard side panel.
Pry open the side dash cover to expose the fuse panel.
Pull 12v power from a fuse (I indicate the 15 amp fuse here since it's likely to be switched power...only on when the car is running.) The mounting bolt indicated should be good for Ground.
To pull power from a fuse, strip about 1/2" of insulation from the power (red) wire. Pull the fuse from the block. Wrap the exposed wire around either of the fuse's blades and push the fuse back into the block. Friction will hold the wire in place.
For Ground, loosen the bolt. Strip 1/2" of insulation from your ground wire (black) , place the exposed wire under the head of the bolt and tighten the bolt down over it:
Attached Thumbnails V1 or K40 install on S550 09-apillar.jpg   V1 or K40 install on S550 09-dashcover.jpg   V1 or K40 install on S550 09-fusepanel.jpg   V1 or K40 install on S550 09-insulation.jpg   V1 or K40 install on S550 09-fusewrap.jpg
Old Mar 4, 2014 | 05:16 PM
Atcpup's Avatar
S550
A bit older but does a great job for me. Passport SR7. Was already installed in car when purchased.
Attached Thumbnails V1 or K40 install on S550 09-20140304_154405.jpg   V1 or K40 install on S550 09-20140304_154411.jpg   V1 or K40 install on S550 09-front.jpg   V1 or K40 install on S550 09-rear.png
Old Mar 4, 2014 | 10:42 PM
KeepRtPassLeft's Avatar
1970 220D
Very good radar detector. The laser jammers do not perform well,as they do not work against many of the current LIDAR guns such as the LTI Truspeed, LTI TruspeedS, Digital Ally Laser Ally, and DragonEye Compact. Additionally the shifter heads are supposed to be facing straight forward, not outward following the contour of the grill.
Old Mar 5, 2014 | 07:02 AM
natcahd's Avatar
Veteran: Air Force
2023 S580 (Current) 2011 S550
Mike...Thx, one more pic please of the V1 installed.
ATC..Thx,Looks like you have some shifter head adjustment to do.
Keep...Thx, Very knowledgeable on the subject.{The thermally insulated windshields generally contain a metallic tint that block transmission of any radio signal. That is why a toll transponder and radar detector won't work on the windshield. On most of those windshields there is a rectangle by the rear view mirror that doesn't contain the insulating material. You can place your tolls transponder or radar detector there.}
I dont see any blank area on our windscreen.
Hd
Old Mar 5, 2014 | 08:39 PM
1970 220D
Nat, is your windshield oem?
Old Mar 5, 2014 | 08:48 PM
Atcpup's Avatar
S550
Hd
Nah, works fine the way it is, has saved my *** many times
Old Mar 5, 2014 | 09:26 PM
  #32
natcahd's Avatar
Veteran: Air Force
Keep...Yes it is.
Hd
Old Mar 5, 2014 | 10:10 PM
  #33
Mike5215's Avatar
2016 C300
Attached Thumbnails V1 or K40 install on S550 09-inside.jpg   V1 or K40 install on S550 09-outside.jpg
Old Mar 5, 2014 | 10:13 PM
  #34
natcahd's Avatar
Veteran: Air Force
Mike...Thx for the views.
Hd
