Vehicle Rising Please Wait A Moment - Normal?
It's most likely just the car "settling"
But did it actually say "Please Wait a Moment"?
If it often drops almost completely down in a week, I'd have the suspension serviced even if it likely still isn't critical.
Anyway, I got curious by this fact, I've noticed it for quite sometime but always forgotten to ask dealer. Hope to get a answer from them tomorrow.
My airmatic 220 s500 (yeah, one of the "crappy" ones) can sit for a week and not drop more than 1/4". If its dropping that much, you have a problem.
What, why would only your car have a "park mode"? Can you ask them to refer to some workshop documents that explain this feature, I've never heard of it and would call it
. The pump is not keeping it up when parked, the car would not even use the air pressure reservoir when parked. If the car sinks, there is a leak. If it only sinks slightly, there is no problem. If it sinks a lot, there is a fault. Of course difficult to say when a leak is significant enough to be called a fault.
One should consider height changes from temperature changes, I believe 1mm per Celsius can be considered normal. Like if the car is parked at +5 degrees in the afternoon and it gets -15 degrees at night, 20 mm height change would be normal without any leaks. I understand that in your case temperature changes are not a factor at all.
This dealership seems to be pretty good from what I have heard from other people. They won "best of the best" award, so I would think they have a pretty good handle on things. I do not believe that they have completely finished the diagnostic testing on the suspension. I will post the "final results" when I hear back from them later in the week.
Tnx for the update 1993_300SE, please informs us what is the final answer from them.
Did you ask "how does the suspension behave once the car is parked" or was your question "is there a park mode where the car lowers itself once parked", I'm afraid the answer could have been different.
The quote mentioned 50 mm, I guess you don't mean that much. If the car got down more than 10 mm, all would have recognised the behaviour but so far at least owners of older W221 cars do not seem to have identified this.
What would be different for the air bags at the struts if the car was sitting lower? The air pressure is basically constant, the volume changes.
I'll try to have a look at the related data just in case they have changed something but it would be nice if other owners reported their experience (in addition to those who already reported).
Edited: I had a look at workshop documents and found a change from MY 09 onwards but for neither option nothing was mentioned about a "park mode" where the car would automatically lower itself when parked. Could it be just that workshops talk about the car behaviour when the car is taken into use where it automatically levels if needed for what ever reason.
My car lowered to the point where the front wheels were up under the fenders, unless my memory is imagining it worse than it was, but it was definitely very obvious when I approached the car. I could immediately tell from a distance that the car had significantly lowered.
50mm is 2 inches. That is HUGE!
Your vehicle should never have the wheels tucked into the fenders.
While the car may lower a few mm while sitting, it should never be that low.
Does it do it in the rear as well?
Id be absolutely amazed if this was normal.
