lowered s550
Old Dec 25, 2009 | 09:14 PM
todd01clk's Avatar
s550
lowered s550
i just had my s550 lowered, but it seems like the right side is lower than the left side by half to an inch, is that common? i dont know how they lowered it but not with lowering module
Old Dec 28, 2009 | 02:21 PM
jagata's Avatar
S6 LP640 E500
Mine is similar also, not noticable when driving. I had my wife drive while looking from outside. I know you can have star disnostic fine tune the height.
Old Dec 28, 2009 | 03:54 PM
Venom-AMG's Avatar
21 G63, 21 GLS580, 16 GTS Ed. 1
Did they use lower links? If they did you have to get them to re adjust it.
Old Dec 28, 2009 | 03:59 PM
jagata's Avatar
S6 LP640 E500
Depends if the car is equipted w/abc if not than there is only 1 link for the rear.
Old Dec 28, 2009 | 05:39 PM
CL55_Serge's Avatar
CL65 AMG , white S550 Sport w/ white Giovanna 22s, wild custom chopper
Is it the left front or left rear? Make sure they used links in the front and that it's done correctly. Other way folks do it is by drilling the strut - really bad idea...
Do you have the ABC or Airmatic? Airmatic has a tendency to be a little bit uneven on the rear since there is a single adjustment.
Old Dec 29, 2009 | 11:29 AM
NOLA911's Avatar
g500, e500
This is actually fairly common in the rear ,if you would have measured your heights before lowering, you probably would have had similar results. My car was 1/2 off with airmatic
If in the front, they didnt adjust the links or star settings to match. You can do the links yourself
Old Dec 29, 2009 | 01:21 PM
todd01clk's Avatar
s550
the left back and front is higher than the right front and back. i think he might have drilled the strut but not too sure... why is drilling the struts bad?
Old Oct 27, 2011 | 11:39 PM
bojanlaske's Avatar
2000 s43
I lowered many of them and they all seat the same way for driver weight distribution once the car is driving it evens it out
