C-S Transmission mode in 2010 S550 4matic
In 2010 S550 4matic, transmission mode always defaults to "C" mode when restarting car. If the mode is set to "S" either in Park or while driving, car will not retain the "S" mode setting if engine is shut down. Car will always start in "C". Is this correct for 2010? Is outside temperature a factor?
2015 White/brown Nappa S550, '13 S550 4 matic, 11 S550 sold, '10 S550 Sports BLACK 08 S550 P3 sport
2015 S550, 2015 SL550, 2015 Lamborghini Huracan
I had the 2007 S550, and when I picked up the 2010 S550, the transmission defaults back to "C" mode after you turn off the engine. Didn't like it, but after driving for a month, I found out that the "S" mode behaves differently from the previous generation (2007). I find the "S" holding on the gears longer and more aggressive. Slight pressure on the gas pedal will downshift the gears. Definitively more aggressive than previous version. I think that's the reason why the gear defaults to "C" mode now and to save gas.
