2010 LED Lights update..
"it IS possible to install the modelupdated lights and bits in a prefacelift 221 BUT:
- you have to install slightly modified taillights in order not to geta taillight malfunction
- you have to get a pre-programmed front SAM in order to get theheadlights to work properly- you have to change the connectors at the headlights and you have toadd wiring to those headlights (this can be done with adapterharnesses)
- I believe that the active cornering feature of the headlights nolonger works properly- as a lot of people do this modification, it is nearly impossible tofind used parts and you will have to get it all new (which is notcheap) ...but, all in all
- it is most definitely possible... "
