2011 S-Class: Bang&Olufsen Soundsystem, BlueTEC model and active assistance systems
211.020 - E 280 CDI
Not sure if this was posted before - if so, please delete this post!
I really hope that all these features will come with the 2011 or 2012 models to the USA…
and some photos of the B&O Soundsystem:
Originally Posted by Mercedes-Benz press release
The new S 350 BlueTEC which is now available from Mercedes-Benz is the most efficient and safest S-Class ever. And thanks to AdBlue® emission control it also offers one of the cleanest diesel models in the world. With combined fuel consumption of just 6.8 litres of diesel per 100 kilometres (NEDC) – corresponding to CO2 emissions of 177 grammes per kilometre – the new diesel model is eleven percent more economical than its predecessor. At the same time, the power output is up ten percent at 190 kW (258 hp) and torque is 15 percent higher at 620 Newton metres. In addition, the S 350 BlueTEC already complies with the emission levels which are planned for 2014 with the introduction of the EU 6 standard. Other new features for the S-Class of model year 2010 include Active Blind Spot Assist and Active Lane Keeping Assist.
The new S 350 BlueTEC combines outstanding safety and comfort plus performance on a par with an eight-cylinder vehicle with the excellent fuel consumption and emission values of a mid-size model. At 6.8 litres per 100 kilometres, the S 350 BlueTEC undercuts its predecessor model by 0.8 litres. CO2 emissions have similarly dropped by eleven percent, from 199 to 177 grammes per kilometre. At the same time output characteristics have improved, maximum power output rising from 173 kW (235 hp) to 190 kW (258 hp) with the current V6 engine and torque hitting a massive 620 Newton metres. The highly efficient and clean V6 diesel engine assures the luxury saloon of impressive performance, with acceleration from 0 to 100 km/h in just 7.1 seconds and a top speed of 250 km/h (electronically limited).
BlueTEC is a technology developed by Mercedes-Benz to reduce emissions from diesel vehicles, in particular nitrogen oxides. To this end AdBlue®, an aqueous urea solution, is injected into the exhaust flow. This releases ammonia, which converts up to 80 percent of nitrogen oxides into harmless nitrogen and water in the downstream SCR (Selective Catalytic Reduction) catalytic converter. As a result, the S 350 BlueTEC already complies with the emission levels which are planned for 2014 with the introduction of the EU 6 standard. The AdBlue® tank is installed under the luggage compartment floor and has a capacity of 25.7 litres. The tank is replenished at the regular maintenance intervals every 25,000 kilometres. The price for the new S 350 BlueTEC stands at € 76,279.00.
Active Lane Keeping Assist and Active Blind Spot Assist
In parallel with the CL-Class, Mercedes-Benz is also introducing two new safety systems for the S-Class which can help to avoid dangerous situations and accidents. When the wheels pass over a broken lane marking, the system activates an electric motor in the steering wheel which triggers brief vibrations – a subtle but effective warning signal. Active Lane Keeping Assist takes effect when the vehicle unintentionally passes over a continuous line to the right or left of the lane. In this case it gently brakes the rear wheel on the opposite side of the vehicle to counteract the drift away from the lane. Active Lane Keeping Assist employs the ESP® electronic stability programme for this purpose.
Active Blind Spot Assist is now available as a further new feature for the S-Class. This system warns the driver by means of a red signal in the glass of the exterior mirror when it detects that changing the lane may lead to an accident. Close-range radar sensors scan the area directly alongside and behind the car for this purpose. If the driver ignores the warnings and a vehicle in the neighbouring lane comes dangerously near – when cutting in after overtaking, for example – gentle corrective braking intervention will take place via ESP® on the wheels on the opposite side of the vehicle. This results in slight yawing of the saloon around its vertical axis as a result of the varying brake force distribution.
Where an accident is nevertheless unavoidable, braking intervention by Active Blind Spot Assist helps to reduce the severity of impact. Active Lane Keeping Assist and Active Blind Spot Assist are available for the S-Class now as part of the Driving Assistance package PLUS.
New leather appointments with stitching
To personalise the interior of the S-Class, Mercedes-Benz is also offering new, high-quality leather appointments which underscore the luxury saloon's exclusive character. A defining feature is the contrasting stitching on the PASSION leather package and the Exclusive PASSION leather package (standard for S 600). Colours and scope of appointments vary according to upholstery and package contents.
The PASSION leather package features the stitching on the fine leather of the seats and armrests as well as on the top and bottom of the instrument panel support and the door panelling, all of which are finished in ARTICO, a man-made leather which is pleasant to the touch. The Exclusive PASSION leather package features seats, armrests, instrument panel support, door linings, ruffled pockets and a rear shelf in fine leather with contrasting stitching. Alcantara is used for the roof liner and to cover the A-, B- and C-pillars.
Tailor-made high-end sound system
The new Bang & Olufsen BeoSound AMG sound system tailored to the luxury saloon's interior is available as a further new feature for the S-Class (standard for S 65 AMG). A combination of 15 loudspeakers and two amplifiers with a total output of 1200 W ensure a thrilling quality of sound from this high-end system. The algorithm of the digital sound processor allows a choice between high-end studio sound and surround sound, and the audio output can be focused exactly on the seat positions of the driver, front-passenger, rear seats or the centre of the interior.
Music can be enjoyed on long trips without tiring the listeners, thanks in particular to the dynamic compensation of driving noise: a microphone integrated in the roof lining between the gullwing doors provides a continuous supply of data on the current interior noise level. The digital sound processor analyses all the frequency bands and increases the volume according to the vehicle's speed – via individual adjustment of each loudspeaker and the different frequency ranges.
Finally!
Some decent sound system to accompany that beautiful car.
Personally, I can't stand that Harman crap.
Wow - finally a better sound system! Personally, I like the current Harman, mainly because I came from BMW so MB Harman kicks *** when compared directly to what BMW had to offer.. New 500/550 engine and the new sound system are good reasons to upgrade.
1998 E320, 2010 E350 P1, 2010 S550 P2
B&O look nice. Any information on new colors if any? E Class had a beige for 2010 but looks like is being axed. Any similar color going onto S for 2011?
Surprised it isn't standard on the 600 too.
I mentioned in the other thread but my father's had two A8s with the B&O system and it is phenomenal. The A Pillar speakers are particularly funky looking on the W221 incarnation!
(This is only slightly a sour grapes comment - I have a 2010)
imo the current harman system is very good. i remember inside line raving about it when the car first came out. I find that it matches the system in the flying spur which has a big Naim system. Paying 6k or 7k as an option would be ridiculous as I doubt it would be anything better than what they put in the Bentley. Tweeter styling is odd considering the rest of the interior.
And also, any sound system sounds horrible when listening to the horrible compressed sounds of Sirius (or XM).
In my (not so humble) opinion, current Harman system is utter garbage. Flat midrange, no soundstage, no clarity, highs are muddy, base is separated, sounding almost as a entity living by itself. The system shouldn't' be offered in C-class.
Even artificially inflated Bose prior the current system sounded better. Nothing fabulous but listenable.
Regarding Sirius, I understand - "garbage in, garbage out" but even with good audio CD, the system doesn't sound much better.
That would be a big surprise.
The system costs 8,449EUR with Splitview in Germany (mercedes.de S-klasse konfigurator), itself costs 7,497EUR. 9,817,50EUR if you choose rear entertainment.
the tweeters look better than the abortion on the Audi A8's. I understand what they are trying to achieve with position of the speaker in the sail panel though, however it is like the original Bose system for home. I would like to see how it sounds with an off axis mount with a reflecting plate vs a quality soft dome tweeter on axis low in the A pillar.
the HK system isn't too bad,
anyone want to pay Porsche Burmester price?
1 Post
'10 MB S550, '11 RR HSE LUX
I personally find the audio system to be one of the most important car features; would definitely get it even as a $10k option if the quality justifies it. The current HK is just fine, but the 1992 Lexus Nakamichi was the best system I have ever had in a car. Mercedes has never been great with their systems ("no highs, no lows -- it's a Bose"), but it's still worlds better than BMW.
I would recommend after-market if you are spending 10K. Granted there are only a hand full of shops that can pull it off professionally and perfectly. I have done one in a 221 before along with a Maybach and it is challenging to say the least. Not hard, but for proper imaging, staging, timbre, and impact... not to mention trouble free operation for many years of use and not chopping up a vehicle, a lot of speaker placement and testing went on. I used Audison amps and Hertz speakers as I found that they perform way better than anything else out there... however that was before Audison released their thesis line of speakers.
Also I do have to give JL Audio some credit for their TW5 flat Piston Subwoofer which I used in the factory location.
1 Post
I'm not big on aftermarket stuff. I trust the manufacturer to get the car right; otherwise, I won't be buying it. I will get the upgraded sound system as an option on my next S-Class despite of the high cost if I like it. So far, I'm reasonably happy with the 2010 HK sound.
I did do a brief search but couldn't see anything. Looks like the B&O system is standard on 600s in the US. It certainly isn't an option in the build your own section, not that I could see anyways.
Good news for prospective W221 S600 buyers like myself
