Warranty coming to an end - Issues persist
SL550 Designo Crystal & Red Interior - SL55 Silver & Black Interior - E550
So I got the 2007 550 about 3 weeks ago and took it into the dealer for a few items. One of them was interior lighting. At the time they told me they would not troubleshoot the problem because the car had an aftermarket windscreen and it could interfere with the sensors. I've just had that changed.
Then I had a problem with the key fob and especially the trunk release. Trunk would not work from the key, the handle or the door button. Cycle the car on and it worked. They said bad battery in the back and changed it. A week or so later, problem has returned.
I have an issue with parktronic. While I understand that you have to choose which mode of parktronic to use, every time I turn the wheel I get the error message about the wheel being turned too far. The parktronic was completely inoperable the first time I took the car in.
Then I have a noise which I thought originally might be brakes in the front left. It occurred at about 5 - 20 mph but it was present braking or when I was not using the braked but at the same speed. Dealer told me that I needed a front end alignment and change the tires. Both have been done and same problem.
I also have a problem with the radio/cd/sat radio/ipod cutting out for a second every now and then. Dealer told me it probably had something to do with the rear battery and since they replaced it, I should not have to worry anymore. Problem still exists.
So.... I have 150 miles left on this warranty and I'm getting ready to take it to the same dealer. Is this a wise choice. Also, what happens if they don’t get it right this time? Once I go over the 50K miles and I just stuck or will they take care of this problem if it reoccurs?
Anyone got any advice for me please? Thanks in advance.
Take it to another dealer, explain the last dealer was unable to resolve your issues and request the shop foreman test drive the vehicle with you as a passenger to identify each concern.
But what happens iof they dont fix the problem first time? Am I stuck as soon as I go over 50K miles? I have 140 left!
When making your appointment with the new dealer have the rep note your mileage confirming you are under 50000. All repairs documented on invoice will be (arguably) covered for 12 months/12000 miles whichever comes first even out of warranty. If dealer refuses to revisit at no cost within this period, contact MB for support.
I had some trouble with my dealership, and then I got the survey email and explained EVERYTHING.
Nothing but smooth sailing the next time I went in for a treatment! In other words, tell on their azz!
