Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension
- Mercedes-Benz C-Class: Why is Suspension Noisy?
Guide to diagnose trouble and recommended solutions
Cracking noise from suspension when going over speed bumps
#53
08 S550 Sport
#54
Hi,
I have the creaking too on my '07 S350 . I'd really be grateful to have the bulletin emailed to me at maxtehcat@optusnet.com.au
#55
Hi,
If possible please would one of you send me the bulletin, having the same problem with my wife's B Class. Thank you in advance. norval.crosson@gmail.com
#56
Hello fellow members. Would somebody please send the bulletin to drh1428@gmail.com that would be greatly appreciated. I experience these similar noises from the suspension when going over bumps when
And when I turn the steering wheel left and right and the noise is very loud and embarrassing. Hope somebody can help me out. Thanks.
#57
Received 4,440 Likes
'71 Pinto
#58
#59
'71 Pinto
Here is MB bulletin LI32.35-P-047253 inclusive of repair process: http://workshop-manuals.com/mercedes...ises_on_bumps/
#60
Can u send me the link please
Kayman1@hotmail.co.uk
#61
Is this applicable to cars built after 2011 as well? My 2011 w221 is making noise similar to what is described in this thread but if the TSB date is 2009, won't MB correct this problem in 2011 year cars?
A PDF of TSB is available here:
https://mbworld.org/forums/attachmen...ay-10857-2.pdf
#63
I started experiencing a cracking noise while going over speed bumps about 3 weeks ago. It happens most prevalently when I go at a speed bump straight ahead and doesn't happen if I do it very slowly but does at reasonable speeds. It makes the noise on the rebound and not on the compression. If I take the bump from the left or right its much reduced or not there. I sometimes hear if it I go over a big dip on a road. The frequency of the noise is decreased when the car is raised. There is no notable effect on the ride or handling of the car. The sound is definitely coming from the front suspension and not the rear. Also it increases in frequency when there are more people in the car.
I don't really want to bother taking it in right now (since my dealer is so far) if it's not serious like when I took it in for sway bar bushings that were causing a creaking.
Anybody experienced anything like this? Car is an 07 S550.
#64
I seem to have the same problem with my 2008 S550.
Thank you very much.
#65
'71 Pinto
Could you please email me a copy of the bulletin? My email address is alicjakb@yahoo.com.
#68
My S550 just started having the creaking/squeaky noise on the passenger front suspension. First thing I did was grease up all the ball joints with white lithium grease which didn't have any affect on the noise. So I sprayed the grease where the sway bar mount meets the sub frame and voila the noise has disappeared just like everyone has said.
I don't want to take it into the dealership but do have a independent shop here that I've taken my car to before. So instead of the temp fix I'd like to get the epoxy/glue done but was curious on what a ball park cost would be or could it be DIY? If so what are the steps to do this.
Thanks in advance.
Thanks in advance.
#69
2016 Mercedes S550
I tried this gluing thing and all the noises went away but came back after a week...did we not do the glue procedure correctly or is this just a reference to making sure that the bushings are the problem here.
I'm deciding to replace all the sway bar bushings...
#70
What's the difficulty level of removing and gluing the bar?
#71
Clunking noise front left when going over bumps
2010 s550
When I go over bumps or make a sharpe left turn i get a clunking noise.
indue shop told me i need to replace both front shocks, control arm bushing and sway bar and sway bar links…. $5000
And fixes that someone can help me with or a shop in north nj or ny thats reasonable please
#72
can u email me a copy of the bulletin please
easymoney456@hotmail.com
#73
'71 Pinto
#74
Can I get the post for the front suspension fix on the stabilizer.
My email is ajtsarukyan@yahoo.com
#75
Can't people read. The link is mentioned at least 10 times in this post, Konigstiger, you have the patience of Job.
