Tires
Old Jan 2, 2011 | 01:13 PM
Em Bee Lover's Avatar
CL550 1976 450 SL
Tires
Old guy who is not performance nuts. Simply enjoy the 221 4matic, usually in "c" mode. Staying with original 18" original wheels. Looking for year around use. Live in snow country. Has original issue Continentals. Michelin Pilot HX MXM4 o k to put on? Seem reasonable at $225/tire. Have driven before on the 220. Recommendations?
Old Jan 2, 2011 | 07:21 PM
carsnob's Avatar
2007 S 600 / '06 911 Porsche C4S cab
Don't do it. Spend the money and get 4 winter tires. Below 45 degrees, the rubber of summer tires hardens and your grip is comprimised. Add cold rain or especially snow and you are asking for trouble.
Then switch in the good weather to summer tires designed for the warm pavement and wet roads. Whether you spring for a second set of rims is up to you (advisable if you're keeping the car for years) -- easy to switch each season plus the tires all last twice as long anyway. I live in Ontario and have driven the S Classes for 25 years and that's the only way to go...
Old Jan 2, 2011 | 10:09 PM
nyca's Avatar
I can't comment on the "hard winter" issue - but the advice on a separate winter set sounds good.
All I would add is - look at the Michelin Pilot Sport A/S tire, instead of the MXM4 - you should find the A/S to be higher rated, and less $$$s. Read reviews and see pricing at tirerack.com for your application.
