clear side marker lights for the s550 ??? where did you get yours
mercedes 2011 CLS550 with AMG package
I am interested in changing the side marker lights on the s550 to clear (OEM are yellow). I installed the updated style for the rear tail lights (2010) and they look and work fantastic on my 2007.
Now I would like to change out those yellow side markers.
Where did you get them
I can't recall what company makes them.. I'm still debating if i wanna put them on my car or just paint the stock ones. They did come with bulbs but i suggest if you are going to put the clear ones in to go with a led bulb to give it the look it deserves.. But it's just a suggestion
These are the bulbs I've used in the license plate lights,mirror puddle light,side marker light,door light (when you open the door,there's lights under it),and parking light (inside headlight). You can also use these for inside the car since it's all the same bulb type. No error messages.http://cgi.ebay.com/ebaymotors/LED-W...ht_4784wt_1167
S550 4matic, ML350
I have the clear ebay side markers as well and the bulb does not come with so an LED upgrade will finish the look nicely! Not a fan of the purple or deep blue but the bright white LED looks great IMHO...
What are the brightest led lights I can get for the parkinglights and side markers? Are these 8 led ones brighter than the 5 led ones mentioned above?
http://item.mobileweb.ebay.com/viewi...8404019&back=1
Thanks in advance.
Thanks in advance.
I also have clear side markers w/led bulbs.
http://cgi.ebay.com/ebaymotors/07-09...ht_5807wt_1182
I just purchased the set on ebay with following your link. I will let you guys know how they look when they get installed
S550 4matic, ML350
Hi Phat- I ordered the LEDs from the same vender and they just blink a few times and dont work. I tried another vender and the same thing... Did your LED side marker bulbs work out of the box or was there something needed to be done to get them to work?
I can't believe how sharp that looks! Im tryin to figure out how many bulbs to order i wanna do every bulb i can like that.. how many did u order? and can u put those in where it lights up in the headlight when makin a turn? Also did u change ur hid's in the headlights or fog's? what color best matches those bulbs? Theres nothing worse then having all miss matched bulbs
-side marker
-parking lights (inside headlight,near side marker)
-mirror (puddle lights) this is tricky to get to.
-both front doors (under door)
-both rear doors (under door)
-inside front footwell L/R
-inside rear footwell L/R
-glove box and center console
-license plate
-trunk
-inside trunk
So these bulbs also are good for the Fog light?? That is the first thing I would ike to change cause the fog lights just does not match the headlight. I would love to get the fog lights to match my main Head lights. Will these bulbs do it?? Thanks
You will need different size bulb for your fogs. The link I posted about are (wedge style) bulbs that are used for interior,side marker,license plate lighting etc.
Thanks for the reply. Have you done that upgrade to your Fog lights and if so you mind sharing the info on what bulb do I need and where to get it? Thanks
