W221 S-Class Headlamp Retrofit
Old 02-24-2012, 09:32 AM
  #51
phatisfy's Avatar
S-class
Was the front bumper absorbers used? If so, which ones? Also how we're the drl's connected? Thanks
Old 02-24-2012, 08:14 PM
  #52
lei996tt's Avatar
S550
Originally Posted by phatisfy
You have to change out the plastic pull handle since the new grill has a different shape. I had to do it on mine so I can confirm for you.
Thanks for the info. Where can I get that part? Dealer?
Old 02-24-2012, 10:12 PM
  #53
phatisfy's Avatar
S-class
I got an aftermarket S65 grill from ebay and it came with the new pull handle.
Old 02-24-2012, 10:55 PM
  #54
lei996tt's Avatar
S550
That's what I did too but I didn't see the pull handle.
Old 02-24-2012, 10:58 PM
  #55
phatisfy's Avatar
S-class
You should contact the seller? Otherwise I don't know if the dealer even sell that part alone?
Old 02-25-2012, 04:23 AM
  #56
Chris The Swede's Avatar
W222 S63L, ML/GLE350
It should be included. And yes they sell the original handle separatly. Partnumber A2218800564 !
Old 02-25-2012, 07:01 AM
  #57
lei996tt's Avatar
S550
Old 02-25-2012, 09:47 AM
  #58
phatisfy's Avatar
S-class
What's the part # for the s550? I broke mine trying to take it off. LoL
Old 02-25-2012, 10:12 AM
  #59
But you have the S65 grill right?
Old 02-25-2012, 10:15 AM
  #60
phatisfy's Avatar
S-class
Yes I do. I just want to know just incase I need to change it back to stock?
Old 03-03-2012, 05:17 PM
  #61
SPONSOR
DCTMOTORSPORTS's Avatar
W211 Estate
Few more pics of the tips.
Order here
https://www.sonicms.net/index.php?ro...product_id=678
Old 03-03-2012, 05:20 PM
  #62
SPONSOR
W211 Estate
All original parts? Even the Carlsson lip?
Yes all OEM MBZ parts. The front lip is Authentic Carlsson.
The exhaust tips are the only non-OEM part we utilized for the retrofit.
Old 03-03-2012, 11:36 PM
  #63
E36c_AMG's Avatar
Does the night vision work with new facelift lights?
Old 03-04-2012, 02:12 AM
  #64
Yes.
Old 03-04-2012, 04:24 AM
  #65
cool_lagoon's Avatar
(1960) 300d, S550 AMG S500 S600 560SEL
night vision camera is located in front center of the condenser coil and radiator and it has its own sensor and functions separately from the headlights. With or without the headlights if you decide to activate the camera it will work independently.
Old 03-04-2012, 05:20 AM
  #66
Diesel Benz's Avatar
Originally Posted by alensiew
is it ILS system can function properly?
Originally Posted by DCTMOTORSPORTS
Yes all OEM functionality is retained.
ILS lights at least in Europe mean automatic high beam switching and adaptive light patterns and beam range (not just high beams on/off). This works from a camera at the windscreen, has the camera been retrofitted along with the new headlights then too?
Does OEM functionality here mean the same as the pre-facelift car had from the factory or the same functionality as the facelift car would have with these new headlights?
I guess you were after the IR emitters at the head lights? Night view would work without these emitters but would lose performance (range). But I don't see why the new lights could not have IR emitters too.
Old 03-04-2012, 11:36 AM
  #67
E36c_AMG's Avatar
Yes,i was thinking about IR emiters in the headlights!It doesnt metter i have decided to convert my car to prefacelift model,i like it better....
Old 03-04-2012, 11:44 AM
  #68
WHAT???? Remove the facelift and add old style? Or you mean you will upgrade to old style S63 kit?
Old 03-04-2012, 12:12 PM
  #69
tonykharper's Avatar
2007 S 65
Please give me first dibbs on your facelift parts if they will fit my 2007 S65.
Tony
Old 03-11-2012, 04:54 PM
  #70
justforfon's Avatar
S classe
The is all you need for facelift or contact the
http://www.carworld-berlin.com/index...di3h9do64ufk07
Old 03-11-2012, 05:05 PM
  #71
To expensive and you dont need all that for a facelift.
Old 03-11-2012, 05:59 PM
  #72
justforfon's Avatar
S classe
What do you mean, you need facelift SAM, Led controlers, harnes and lights? where i can get chipper?
Regards dan
Old 03-11-2012, 06:30 PM
  #73
No you dont need sam. You only need lights,units and special adapter cable set. You got PM.
Old 03-12-2012, 07:16 AM
  #74
XALLECS's Avatar
s320
CAN u explain me beeter .. i already buy the new headlights ... so i don't need sam ? new facelift sam? thank you i wait your answer
Old 03-18-2012, 03:23 AM
  #75
trigital's Avatar
W222
Recap, please!
Your adapter loom has resistors or not?
The Active Curvenlight (Not Cornering) will work?
The DRL dimm when low beam is active?
How do you turn on the DRL?
As I know the old SAM can not light up the DRL without hardware/software modification.
Quick Reply: W221 S-Class Headlamp Retrofit
