W221 Express Closing on Panorama Roof
Old Aug 11, 2011 | 07:00 AM
rasheed1397's Avatar
Mercedes Benz S550
Question W221 Express Closing on Panorama Roof
Anyone knows the logic behind the lack of express closing for the panoramic sunroof and sun shades on the w221?
Is there a mod out there that allows express closing of panoramic sunroof and shades?
I just can't understand why the regular sunroof has express closing but not the panoramic one
Old Aug 11, 2011 | 07:23 AM
Diesel Benz's Avatar
The express closing isn't actually missing from the W221 pano roof, it is just missing from the early models. I guess does not make you feel any better. Difficult to see any safety issue there or other logic.
Old Aug 11, 2011 | 08:03 AM
IDriveAnM5's Avatar
'10 S550 4Matic, '06 BMW M5
Yeah, my 2010 has express for all of those things!!!
Old Aug 11, 2011 | 12:24 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
It's kind of annoying, I wonder if they can just program it in?
Old Aug 11, 2011 | 07:52 PM
Mercedes Benz S550
hmmm...how unfortunate I wonder if this is something that can be done via a software update?
Old Aug 12, 2011 | 06:37 PM
nadir813's Avatar
2010 S350
What do you mean by express closing?
Old Aug 12, 2011 | 07:36 PM
Mercedes Benz S550
One touch closing i.e. not having to keep holding the switch until it's closed all the way.
Old Aug 12, 2011 | 09:21 PM
HiTach's Avatar
E400S4 '17
Doesn't the express need an extra indent on the switch?
If so, I don''t think software would ever work.
Old Aug 13, 2011 | 03:49 AM
The switch is different but DAS allows these settings to be modified via version coding and it looks like it could be possible to activate one touch from the existing SW if the switch was changed (at least after SW update to the control unit).
Old Aug 14, 2011 | 01:44 AM
Mercedes Benz S550
That's a good point. I don't know the differences in the physical looks between the two switches, but I notice that when closing there's no going beyond the resistance point. However, while opening, going beyond the resistance point puts it in Express Open mode. So it makes sense that if the physical switch doesn't allow going beyond the resistance point I don't know how the software will tell the diff. between manual and express closing? Unless it would do away with manual closing and just go straight into express closing.
Old Aug 14, 2011 | 03:23 AM
Super Salami's Avatar
'08 Designo S550, R32 Nissan Skyline
I remember reading somewhere about it that it was an obstacle sensor issue. Say something was in the way of the track, since our roof goes up and above, when it's closing, I guess it's harder for it to tell if something is in the way and to tell it to stop. Still makes no sense why either the front or the back sunshade for can't be one touch close though??
Old Aug 14, 2011 | 09:37 AM
Mercedes Benz S550
hmmm...if that were the case, why is it that some ppl have express closing on the panoramic roof enabled?
Old Aug 14, 2011 | 11:55 AM
Well I was just trying to find where I read it before but can't. I did however find another thread in this same forum talking about the exact same issue and someone there posted a pretty good tip. Holding the air recirc button on the dash closes everything, which is much better imo than holding your hand up there like an idiot. Haven't tried it personally but people are saying it works for pano too so I'll def be closing it that way from now on.
Old Aug 14, 2011 | 10:17 PM
Mercedes Benz S550
As weird as that sounded I just tried it out and it actually worked...go figure. However, unfortunately this doesn't solve the problem because the "recirculate" button still doesn't offer express-closing and I have to keep holding it all the way
Old Aug 15, 2011 | 12:40 AM
dannieboiz's Avatar
That would be the best resolution as far as I can see, good enough for me, who needs a solution. Why didn't I think of this before, I think it's a standard feature for most if not all newer benz.
Old Aug 15, 2011 | 06:24 AM
Mercedes Benz S550
The only thing this solves is that you don't have to hold your hand above your head to close the sunroof but you still have to hold it until the sunroof is fully closed...and if the sun is beating down on you you still have to use the overhead switch to close the shade as the recirculate button seems to only close the sunroof. So while I think this is neat, it's still nothing like one-touch closing
Old Nov 9, 2011 | 10:38 PM
malahhaor's Avatar
06 Carrera4
So I've noticed that there is no express close on the sunroof as well. Whatsnup with that?
Old Nov 9, 2011 | 10:59 PM
dannieboiz's Avatar
Do u have Pano roof? then you won't have express close
Old Nov 9, 2011 | 11:01 PM
malahhaor's Avatar
06 Carrera4
Yes I do. Why would it matter? Any idea?
Old Nov 10, 2011 | 04:20 AM
Did you read this whole thread or at least the previous post from dannieboiz?
Early W211 cars with pano-roof do no have the express closing feature. This is what the thread is talking about. If you wanted to know why, you can find some views from this thread or other similar threads but only MB knows for sure.
Old Nov 10, 2011 | 08:13 AM
malahhaor's Avatar
06 Carrera4
No need to be an a$$ I read the entire thread. I thought it was referring to the sunshade on the panoramic sunroof, which is the glass in the back, not the sunroof it self above the driver.
