Where is the fusebox for the AC plug
I want to wire up on radar detector to the fusebox but the fusebox by the left and right front doors stay on even when the ignition is off so these fuses don't work.
I don't have a manual to direct me where to look.
Thanks.
What wire color did you tap into it? There is not alot of wire there to work with ..how did you do yours?
Thanks.
Thanks..i was able to jam the wire into the harness...didn't want to cut the wire and have a reason for mercedes to void my warranty..thanks and i"m all set now...
starting by the mirror,
tuck the wire underneath the headboard.
.run it towards your right.
Then tuck the wire down the a pillar
and then behind the fuse box by the passenger side door
Then run the wire underneath the passenger knee area below the glove box
and then into the cigarette lighter
Let me know if this makes sense?
Where did you mount the radar? exactly right of the rear view mirror? how is the reception ?
I do not want to put there as i wont be able to use the sun shade then as the passport 9500ix is long and narrow.
I am prolly gonna put mine in the low middle center and run the cable the way u did, just not all the way up rather across the dash to the unit.
I asked this ebay seller here:
http://www.ebay.com/itm/ESCORT-REDLI...ht_3196wt_1231
to make a special adapter for the sclass. They told me that they purchased a sclass mirror so that they can fabricate the mount for this. That was actually last year so i'm going to contact them so that the detector is no longer mounted on the windshield.
That will also solve your sunshade issue.
http://www.mbusa.com/mercedes/owners...007c184335RCRD
