2007 S550 when cold engine sounds like a boat exhaust going in and out of water
Old Nov 30, 2011 | 06:09 PM
laxexquis's Avatar
2007 S550
Hello
I have a 2007 S550 84,000 miles with an 11/05 build date so I believe it is possibly effected by the timing chain issue, in fact the check engine light goes on intermittently, I haven't gotten it checked to see why, frankly I am afraid to as the car was running fine up until now.
When driving the car cold it literally sounds like a boat where the exhaust outlet is coming in and out the the water on a wavy day, in other words the cars engine is more muffled and normal and it goes in and out to loud again and again. In fact literally does sound like some sort of exhaust being muffled and unmuffled by a liquid because when going over a bump it sounds like suddenly the sound is muffled like a liquid inside the engine got stirred up and covered the sound.
It's very weird, it goes away mostly once the car is warmed up are a little after it is warmed up. Otherwise the car seems to be running fine power wise and mpg wise, I am wondering if anyone has experienced this or if it is related to the timing chain issue.
Old Nov 30, 2011 | 07:17 PM
lylesr33's Avatar
Black 2008 S550 sport 2011 E350
Have you had the engine and transmission mounts changed? That may be the issue with the "boat exhaust" sound you're hearing.
Old Jan 24, 2012 | 08:24 AM
malahhaor's Avatar
06 Carrera4
Could be air pump. my wifes CLS had that problem. Sounded exactly as you describe. Since it mostly comes on when engine warms up. And as i was talking to my friend mechanic at the dealler another one rolled up with same issue.
dealer cost i think like 1100 bucks to fix, but you can get one on fleabay for 400 and instal in 30 min
Old Jun 10, 2012 | 10:44 AM
hubbard316's Avatar
Exclamation
I have this same issue with my 07 S550.
Anyone resolved this yet?
Ive also gotten a P0025 fault code which I hear is the cam magnets needing to be replaced.
Anyone here can help???
Old Feb 27, 2013 | 07:26 PM
Cincy1's Avatar
'08 S550, '92 500SEL
Motorboat sound
I have a 08 S550 4matic and I get the same in and out of water sound. Like you, it seems more frequent when the weather is cold. Did you ever find out what caused yours to do this? I also get a ticking sound from the front driver side under the hood. Took it in and service agent showed me the part that was making the noise and said it was normal. I had to scratch my head on that one, $100K car louder than a standard Camary?
